1989 331is
reggid
Post Tue May 13, 2014 1:49 pm
final results are in now that everything is tuned.
It just goes to show that ITB and new induction system can make more power everywhere and there are no downsides once you use the right diameter runners, right runner length and feed it cold air.
Made 160rwkw (215rwhp) on one run but this is the best overall powerband.
best part of 30whp gain peak to peak which is a difficult task on the m20
first graph is 42mm ITB, 12" runner length and custom GRP/CFRP airbox and K&N filter Vs a BMW OEM casting with some massaging done to it
with airbox trumped the open trumpets which was good though some nodoubt due to the tune.
graph is as above but with open trumpets also added into the mix
had a few issues, the throttle got jammed WOT on the dyno (better there than on the street). Already had a spare at home because it started to look a bit frayed. the internal sheath deteriorated due to long term heat exposure from the exhaust is my guess and added too much friction. had to baby it home but all sorted now. i now realize it had been on its way out for a long time as the pedal is so touchy and responsive now with a brand new cable. i will adding a bit more spring tension to make it a little easier to drive otherwise it will be a handful in the wet.
E30 325is with M20B31
Post Tue May 13, 2014 3:26 pm
Beautiful... :cool:
reggid
Post Tue May 13, 2014 10:16 pm
thanks man
Post Tue May 13, 2014 11:26 pm
reggid wrote:thanks man
Are you "JPS E21"??
reggid
Post Tue May 13, 2014 11:49 pm
no, Rama has an e21 JPS i have an e30 325is. he lives about 45min away and i have been to his workshop often etc. i bought the kit from him but i made the airbox.
Post Tue May 13, 2014 11:55 pm
reggid wrote:no, Rama has an e21 JPS i have an e30 325is. he lives about 45min away and i have been to his workshop often etc. i bought the kit from him but i made the airbox.
Ahh right.
that's why I asked.
I'm sure he had a similar project going over on another forum. 8)
reggid
Post Wed May 14, 2014 5:45 am
Ahh right.
that's why I asked.
yeah he did a 3L race engine last year
reggid
Post Sat Oct 25, 2014 5:22 am
i have moved the X-pipe from 4th to 3rd harmonic and it seems a positive move.
The AFR or timing has not been adjusted at all and you can see that the engine runs alot leaner in parts now and make alot more power in midrange as i was hoping and no loss of topend hp.
i will get it properly tuned in the next couple of weeks and will update as i imagine there will be some additional gains from a tune
im not sure why the operator ran it from such a low rpm as i never use WOT at 1700rpm in 4th gear, nevertheless 100km/h is 3400rpm so the peak torque is 220rwtq 4200rpm give or take and hp 224whp 6100rpm
reggid
Post Fri Sep 16, 2016 2:45 am
I think it’s time for an update.
So my head is 99% assembled minus some studs, sprayer and the shaft plugs
RHD rockers and 292/292 cam installed. 110 lobe separation with just under 13mm lift. Think schrick 288 but extra 1.5mm lift and a few degrees duration more so nothing too wild (yet).
Valve lift seems to be what a big stroker needs to get VE at any sort of rpm approaching 7000rpm, the roller followers enable a higher valve velocity than you can get with stock type rocker pad giving a nice fat lift curve.
i was going to go for the 306 cam but i thought id start mild to begin with as i want to still drive it on the street without too much compromise, maybe im getting old or just soft ;) however everything is being designed around being able to fit the 306 cam with 106 LSA at a later date.
port work is mint 45/36 valves lots of chamber reshaping (remember that the chamber is an extension of the port...), the RHD intake was fully port matched to.
you can feel the shapes are right with your finger the short side profile is miles better than any head ive had ported before.
Time for the bottom end to get serious. Lightweight 93.8mm stroke crank from an Alpina B3 3.3 / B3S should do the trick for some midrange torque. I wouldn’t expect anymore topend hp compared to 89.6 crank all else being equal but shouldn’t have to rev it as hard.
Post Fri Sep 16, 2016 6:59 pm
What gains do you think these upgrades will yield?
TPS
Post Fri Sep 16, 2016 10:07 pm
Looks Nice
Post Fri Sep 16, 2016 10:29 pm
no replacement for displacement :D :D :D
will be knocking on the door of 300hp soon 8)
reggid
Post Fri Sep 16, 2016 11:41 pm
bss325i wrote:What gains do you think these upgrades will yield?
Last time at my local dyno dynamics dyno/rr it was 155-160kw at wheels this will hopefully make 200kw but there might not be enough can duration so idk. Dyno dynamics don't do flywheel HP properly so can't say what HP that is.
I'm using the big stroke crank for torque, all else equal I don't think it gives much more power if any over a 89.6mm stroke crank as top end ( head, cam , inlet and exhaust ) governs that for the most part due to diminishing returns. The stroke gives more bottom end and midrange which is why I'm using it.
As far as bhp the first number should be a 3. I've been using ENGMOD4T it says it will do more than 300hp. I'll be sure to run it in a Maha dyno for a non BS printout for the flywheel number.
reggid
Post Tue Feb 06, 2018 8:28 am
some new pics
fb
Post Tue Feb 06, 2018 8:55 am
Very nice,well done! What chin spoiler are you using?
steve_k
Post Tue Feb 06, 2018 9:20 am
good to see an update :D
was wondering what happened to this, keep it coming.
reggid
Post Tue Feb 06, 2018 11:30 am
fb wrote:Very nice,well done! What chin spoiler are you using?
Got it years ago from the USA with a fellow forum member to save on shipping.
Sambe30
Post Tue Feb 06, 2018 12:44 pm
Perfection :D
JungleGus
Post Tue Feb 06, 2018 3:42 pm
Love a good M20 Sport
Post Tue Feb 06, 2018 4:40 pm
Cracking car , shame about the location !! (he said watching it snow)
reggid
Post Sat Nov 17, 2018 12:01 am
It’s been quite long size I’ve posted anything of substance so here goes…
A rather important piece of the puzzle is the piston. When you want a custom set sometimes you have to design your own.
There are a few basic fundamental things needed to lock in before getting into details:
BASICS
1) Bore
2) Compression Height CH
3) CR (gives the Piston dome/dish cc)
To answer those I need:
- Block Deck Height – mine is 206.2 mm so allow say 206.0 after machining.
- Rod Length – 135 mm stock.
- Stroke – 93.8 mm (throw 46.9 mm) Alpina B3 crankshaft
- Deck Clearance – Target -0.9 mm (negative is above deck) gives nominally the recommended squish with gasket thickness below.
- Gasket Thickness – I’ve assumed nominal MLS thickness of 1.90 mm (0.075”) I can adjust the squish clearance as there is 1.52, 1.73, 1.78, 1.91, 2.03 and 2.18 mm thicknesses available.
- Gasket Bore – 0.5 mm larger than the bore is a safe bet so 86.5 mm.
- Combustion Chamber Volume (cc) – Mine is 46 cc.
1) Bore
This is easy my current pistons are 86 mm, makes sense to keep it the same especially with a big valve head. Others might like to use 85 mm to be able to use an OE composite gasket. There are 86 mm pistons that work with an OE gasket by having a large chamfer but there are a few things I’ve never really liked with the idea.
This is simple maths
CH = Block Deck Height – Rod Length – Crank Throw – Deck Clearance
CH = 206 - 135 - 46.9 - -0.9 = 25.00 mm
3) Compression Ratio
For a street engine running on 98RON with a cam around 290 duration 11 to 11.5:1 is about the upper limit that is “recommended”, some will say more is ok some will say less is better, in reality it just depends there are many variables. Something around that value with the cam in question gives a dynamic compression ratio of 8 to 8.4. So I split the difference and aimed for 11.25:1. I may look to setup knock control as an added safety measure.
Some more maths to work out the total combustion chamber size with
Swept Volume per cylinder = pi/4 * Bore ^2 * Stroke = 544.9 cc (3,269 cc)
Net Combustion Chamber Volume = Swept Volume / (CR-1) = 53.2 cc
Again some more maths to work the dome/dish cc, it is fairly simple maths
Piston cc = Net Combustion Chamber Volume – Cylinder Head cc – Gasket Volume – Deck Clearance Volume
Cylinder head cc = 46 cc
Gasket Volume = pi/4 * Gasket Bore ^2 * Gasket Thickness = 11.2 cc
Deck Clearance Volume = pi/4 * Bore ^2 * Deck Clearance = - 5.3 cc (this is negative because the clearance is negative i.e. above deck)
Therefore
Piston cc = 53.2 - 46 - 11.2 - -5.3 = + 1.2 cc (i.e a net Dish, a negative would be net dome)
Preliminary Piston Verification:
Will the long stroke work?
There are few issues with using the long stroke:
i) The short CH:
The required compression height is 25mm. This is quite short but not as short as some “off the shelf” pistons from MM.
To do this I decided on a 20mm pin, it allows a bit more room for the ring lands and gives more clearance between the valve pocket and the top ring as well as better clearance between the piston boss and crank. It means getting the rods rebushed and honed to 20mm so it’s not overly difficult you just end up paying a little extra.
Rings are:
1st: 1.0mm Barrel (thermal spray coating)
2nd: 1.2mm Napier. The napier ring is really good for added oil control as it scrapes the wall well.
3rd: 2.8mm 3 piece Standard tension (inc oil support rail)
https://www.youtube.com/watch?v=WCc0OUkTOEE
ii) Piston Boss to Crank Counterweight Clearance
The picture below shows the clearance, people would know that when doing the 2.8L budget stroker this is an issue due to the short rod and large counterweight crank. Fortunately the crank I’m going to use doesn’t have overly large counterweights. They are the same as the S52 and smaller than the M52b28 crank. Also the rods are longer so it’s actually less of an issue than on the budget stroker
Clearance = rod length – crank throw – crank counterweight radius – pin radius – piston boss thickness
= 135 – 46.9 – 70.5 – 10 – 5.5 = 2.1 mm which is plenty of clearance.
iii) Piston deck thickness
With the short compression height and a dish the little end of the rod limits how thick the crown can be
The maximum dish that can be run depends on a few things
The minimum piston crown (in the centre of piston) I’ve seen recommended is about 4.5mm for NA (opinion of people working in the piston manufacturing industry). I think allowing for 5 or 5.5mm is a better idea.
The minimum clearance I’ve seen recommended for the rod to underside of the piston is 1.25mm (JE data sheet)
https://www.jepistons.com/PDFs/TechCorn ... rc4032.pdf
The rod has a radius of 16.25mm (drawing provided by the manufacturer)
So the maximum dish = Compression height – rod little end radius – underside clearance – crown thickness
25.00 – 16.25 – 1.25 – 5.5 = 2.00 mm
Piston Design
Dome Design
this is the data for the OE pistons
The OE design has the angled squish pad for generating turbulence in the combustion chamber which helps with the burn speed and reducing knock. It also has the dish offset towards the spark plug and exhaust valve.
With a donor 9.7:1 slug some simple radius gauges you can learn quite a bit
You can also see where the centre of the dish is by looking at the machining marks so you can measure the dish offset
So this is how the stock 9.7:1 m20 piston dome is constructed
Spherical dome (not a hemisphere) approx R100
Subtract a spherical dish approx R106mm
the centre of the sphere is offset in two directions from the bore axis (towards the spark plug) as well as being offset in the piston axial direction
section view showing dish
So in actual fact the squish is not a chamfer it’s slightly radiused. Same with the head the machined part is radiused (concave) to match the piston
Then there is adding in the valve reliefs
The reliefs need to be bigger to account for the bigger valves and deeper to account for the different cam. I ended up designing it for 45/37mm valves even though the exhaust is only 36mm, just in case. I also made the depth bigger to suit a higher overlap cam than I will actually be using first off again just in case. The cam I am using is pretty conservative so I can see something with more overlap being used later.
One issue with a smaller diameter piston such as 84.0, 84.5, 85.0 etc is the larger intake valve pocket get too close to the top ring groove so it needs to be lowered which then makes it harder to fit the rings in the short compression height
Dish Design
Given I need a 1.25cc net dish if I have a dome of -3.15cc then the dish needs to be 4.4cc which needs to be achieved while adhering to a limit of 2mm depth. This required having a modified spherical dish with a small flat section in the centre of the dish. Having a definitive flat section will help with setup of deck clearance when it’s at the machine shop
This is the final dome design done which is basically the same as OE with a few changes to get the CR where I wanted
So it was time to do a few mockups to check the dome to see if the squish pads were correct and that valve relief locations and depth were correct. So I had some 3D printed (with the bore 84mm) so it would fit into the spare block that has stock bore size.
This one was done with one the cheap machines by a mate but wasn’t quite accurate enough for my liking so I had a second one done
I also had valve relief checking device printed to check radial clearance and axial clearance.
Now I had proof on concept I contacted Mahle MS and gave them drawings and a 3D model step file so they can add on the slipper skirt details etc
There was a choice of 2618 (M-SP25), 4032 alloy (M124) & the proprietary Mahle M142 alloy. The latter was only possible with a billet piston due to the restriction of the M142 forging. The billet was $700 more expensive and the difference was judged to be not worth the extra cost as the mechanical property differences are pretty subtle as shown below. The added cost is presumably because of the added machining time.
I settled on 4032 as it’s a street engine that isn’t an extremely severe application and the better wear characteristics and being able to run a tighter piston to wall with a short piston height were the main deciding factors.
FINAL SPECS
Mahle MS pistons
Bore = 86.00 mm
Compression Ratio = 11.25
Pin = 20 mm with an offset towards the thrust side (for quieter running). Offsetting the opposite way does make a little more power.
Install clearance = 0.0020” (coated)
They come standard with
- slipper skirt with grafal coating,
- phosphate coating (reduces micro welding and is actually only needed on ring grooves and pin)
- accumulator groove between 1st and 2nd ring grooves and
- backcut 3rd ring land
- wire clips with tang
The piston mass is = 276 g
The pin is 50L x 20D x 5.0t mm and the mass is = 92 g
The mass of the rings is = 26g
The total mass is = 394 g
Stock piston mass is 375 g and pin 105 g = 480 g excluding rings (est 510g with rings)
So there is no excuse for someone using a flat top with the 885 head ever again :tongue:
EOM
Steve
Post Thu Nov 22, 2018 6:54 pm
Wow, great update thanks, in fact my head now hurts trying to take in all that information. :D
webmaster@e30zone.net
Post Fri Nov 23, 2018 7:23 pm
Very nice! I expect it took you a hell of a lot longer to do than it took me to read :D
reggid
Post Wed Apr 17, 2019 10:47 am
Baby steps….
Painted the manifold and finalised the nipples for
- Idle control valve elbows strategtically angled to suit vacuum rail
- Single Brake Booster nipple
- Seperate Vacuum nipples for synchronisation
the metal plate is an alignment tool so that when i bolt the manifolds to the head the relationship between the the 3 castings is maintained.
i have a seperate plate for mounting the throttles so the shaft remains concentric to ensure that at WOT they each open the same amount
Remade the vacuum rail
A bit overkill but a nice beefy but compact set of aftermarket I-Beam rods. Stock length 135mm but bushed to 20mm. The usual details 3/8" ARP 2000 bolts, forged and heat treated 4340 steel, shot peened…..
Everything in CAD, mostly cause why not....oh and also need to design a crank scraper and windage tray setup. Still work in progress got to get all the holes in the right spot on the block. Some stuff is just representative
Post Wed Apr 17, 2019 3:26 pm
:cool: :cool: :cool: :cool:
Lovely to see some proper engineering and as you said, cad cam is the ONLY way to go .
Quick adjustment of the model, accuracy and repeatability of parts.
NICE. :clap: :clap: :clap: :clap:
reggid
Post Sat Feb 17, 2024 7:33 am
New boots about 6 months ago
reggid
Post Sat Feb 17, 2024 7:34 am
DId a booster and m/c swap along with 300mm/de BBK.
-Year and model of your E30: 89 325is RHD vehicle
-Intake manifold used in swap: m20 RHD ITB setup with own custom airbox. PLanning a new airbox and trumpets hence the mod as it creates more space
-Brake booster donor car: e93 320d
-Brake booster part number:34336779733
-Brake booster manufacturer and manufacturer PN or identifying marks: i thought TRW make them but cant be sure? it has single vacuum port, i oriented port closest to engine but it was on the otherside on the doner vehicle. some have 2 vacuumm ports just block one off.
-Parts needed:
e93 booster 34336779733
e90/92/93 m/c RHS version with ports on outside 25/22 34336785664​
e93 clevis pin 34336753646
spring clip 07129904567
new o-ring for M/C 34311160617
new bung for M/C reservoir 2 x 34311160133
rubber hose for remote mount reservoir
remote reservoir 2002 bottle FTE brand p/n 9790000
connector for M/C to fit hoses for remote reservoir 2 x 34321102282
Booster vacuum port bung 34336765316
2 x M10x1 bubble tube nuts
2 x M12x1 bubble tube nuts
3/16" cunifer brake line
flare tool https://www.amazon.co.uk/Laser-TOOLS-LA ... 9OIKA?th=1
line cutter
-Modifications needed:
booster unmodfied as clevis bolts right up with RHD vehicles as the clevis position is within a couple mm or the stock one but you adjust the brake light switch as required as pedal height changes a bit
to fit booster trim away the firewall insulation with a box cutter and/or scissors
trim the plastic firewall clips that retain the hard lines near the booster and lightly massage the lines by hand so boosters sits flush on firewall
i made two (2) new lines from ABS unit to the M/C using cunifer 3/16" tube and M10x1 tube nuts at one end (ABS) and M12x1 at the other end (M/C).
i dissassembled the rear pressure limiting device and removed the guts and reassmbled (optional step)
-Comments on pedal feel and stopping power: Brake are best they ever felt. i did this with 300mm.de 4x100 312x28 FR and 294x19 RR setup fully rebuilt with new pistons the e34 540i front calipers (60mm piston) and e36 m3 rear calipers (40mm piston)
after replacing almost entire brake system sans hardlines and ABS unit bleeding took a few goes and suggest using a Motive pressure bleeder with BMW adapter and following the steps in link a couple times or you wont get the system bled and pedal will be long and soft
https://bmwe30cabriolet-wdm.blogspot.co ... r-abs.html
you could try a e92 m3 or e60 m5 M/C if you want a harder pedal but the 25/22 seems pretty close to perfect for my preferences.
