Convertible hood roof top seal fix
Joedean
Does anyone know how to fix a slightly leaking convertible hood roof top seal without shelling out 250 pounds which they are going for on ebay? or at least somewhere selling for a more realistic price ?? Any help or recommendations very much appreciated.
M3KUK
I got some stuff to refresh the seals up a bit and some BMW roof sealant, as recommended on here. Not had chance to use them yet due to weather!
Satan
Gummi Pflege, check on Amazon to condition the rubber, also check the window adjustment.
Joedean
nice one peeps! Gummi pfledge and roof sealant it is!! Found a good youtube vid explaining how to wash and protect. Adding a little Vaseline around the seal after cleaning,and applying Gummi pfledge was also recommended.
Satan
Nee to do the seals a few times with the gummy pflege, also do the door and boot seals as well.
Joedean
Cheers Satan =-)
Would you recommend the Roll on or Spay gummy pflege?
Satan
I use the one with the foam end, press down foam soaks up liquid then rub on your seals...... find it easier.
