HUGE thanks to Ant for making the trip down to mine for the day!
We started off by rigging Ant's WBO2 sensor up to the car and giving the Emerald an output from the sensor. For some reason though, the Emerald threw a wobbler and started showing the throttle as being 97% open, even when it was closed.
So that problem was easily solved once we'd spotted it.
Went out for a drive and under certain circumstances, it wasn't too bad. Pulling away with some revs on and slipping the clutch wasn't a problem, but anything more sedate like engaging the clutch and then pressing the pedal caused some pretty violent lurching, no power and some pant brownage
Hills were also a problem so after a bit we went back home for coffee and a think.
Ant spotted that the MAP sensor was randomly subtracting fuel from the whole map depending on inlet vacuum which would explain why it was lean one second, and seemingly with the same speed and throttle position, it was massively rich the next, so all these settings were put to 0 and the new map loaded into the brain.
Started it up to do some work on the no load sites and see what's what, but after a couple of mins it started choking, exhausty smelling smoke started billowing out of the engine bay and it started running like a sack o' shite
Ant tries pulling plug leads to see if it's a sparking problem and sure enough, cyl5 isn't playing ball.
All the plugs come out, all are black, dry and sooty barring 5 which is black and piss-wet through. There's definately something wrong with cyl5 as it seems to pump more fuel out of the inlet than it takes in.
Anyway, plugs all cleaned up and back in, we start it up again but it's still running like crap (even after we've trimmed about 20% of the fuel out of the map) but this time the problem seems to be that the ECU reckons the throttle's half open!
Much head scratching later, we test the sensor with a multimeter and sure enough, it's buggered, giving a reading of about 1/2 the overall value it's capable of giving. To make matters worse, it's tucked away at the back of the head and removing it requires removing the rear set of throttles
SO, plan is to ignore that TPS and fit a new one where it can be more easily accessed.
What a bummer! Still, it's a move in the right direction now that the cause of the seemingly random timing and fueling alterations have been eliminated.
Have to say I'm hugely envious of Ant's extremely professional looking installation! If you just didn't know what you were looking at, you'd swear it left the factory like it! Then, there's the kick in the arse it gives! I've gone through two sets of underwear today due to E30s!
