1987 baur 316 4 speed auto
Can I use dexron II or III in the gear box ?
auto fluid
Topblag
I use II in my 325 auto box.
1984 Hartge H35 in Black
2006 Audi S6 V10 in Black 58k
Good enough for meTopblag wrote:I use II in my 325 auto box.
ECP are doing 5 litres for less than £14 with code.
Cheers mate
It`s the same box I think.......hmmmmmmTopblag wrote:I use II in my 325 auto box.
darkchild
Yep, it'll be fine. Dexron III has largely replaced Dexron II.
I saw a wheeler dealers a while ago and Ed was saying not to put synthetic oil in old box`s and rack`s as the seals can react to this so I plumped for dexron II.darkchild wrote:Yep, it'll be fine. Dexron III has largely replaced Dexron II.
This the same Ed that crowed about the power increase from fitting a cone filter to an E30?
Total bullsh*te.
Total bullsh*te.
He got that wrong and is still doing it !!Brianmoooore wrote:This the same Ed that crowed about the power increase from fitting a cone filter to an E30?
Total bullsh*te.
Unless this will totally ruin my box then I will be using it.
What did they use thirty odd years ago then ?
Dexron II was the original autobox fluid for an E30, along with 20W-50 mineral oil in the engine, and both are fine now, but few would use that spec. of oil in the engine these days if they care anything about the car, and Dexron III is an improved, backwardly compatible upgrade over Dexron II.
