looking to run 16 inch 9j advice needed pls
j4gz
currently on gaz coilovers front and rears am looking to change my wheels from 17s to 16s but with 9j all round what is the ideal setup pls.... and issues to look out for....
Scotty200
A good website to try is willtheyfit.com, put the spec of your current set up of wheels eg size, width, et and tyre size then fill in the spec of 9j wheels your after, the website will give you all the details you need, eg how far out your Speedo will be,any arch gap you will gain/lose, how close to strut, how much more they will stick out etc
Hope this helps
Scott
Hope this helps
Scott
j4gz
cheers scott.
