replacing inner and outer tie rods
arrisbmw
Post Tue Nov 28, 2017 10:31 pm
Hello. has any one replaced their inner and outer tie rods, recently and if so, what were the symptoms before.
did it stop the shaking at the steering wheel at M way speeds
thank-you still trying to stop my wobble at 60 - 70 wondered if could be inner tie rods.
Post Tue Nov 28, 2017 11:21 pm
Worn inner or outer joints could contribute to a wobble, but they're easily checked. Drive the front wheels onto a couple of glossy magazines, ensure the steering is locked, and see if you can rock either front wheel with your hands opposite each other, halfway up the tyres.
arrisbmw
Post Wed Nov 29, 2017 7:35 pm
oh, cheers
I,ll try that i assume hands at 3 o.clock and 9 o,clock.
when you say steering locked , via the steering lock on ignition yes ?
Post Thu Nov 30, 2017 12:34 am
arrisbmw wrote: when you say steering locked , via the steering lock on ignition yes ?
With the steering lock on, and preferably with someone holding the steering wheel hard against the lock.
Without someone holding the steering wheel, there'll still be a tiny bit of movement in the steering wheel, which you may mistake for slight wear in the steering, or more likely, you'll attribute wear to that slight movement, and miss finding it.
arrisbmw
Post Thu Nov 30, 2017 11:13 pm
o.k cheers , when it warmsup a bit get the mrs out there.
