gettin rid of pink panels
jamo
Post Thu Feb 09, 2006 7:02 pm
Any ideas how to get rid of pink panels. 1/2 the car comes up a nice red, the bonnet, drivers door and rear quarter are pink, dont have the money for a respray yet, would a good tcut work? Its really pissin me off as half the car looks really good (':-x')
c76jon
Post Fri Feb 10, 2006 11:07 pm
hi
it is oxidised paint that is making it pink
you need to clay the car and use a quality paint cleanser to remove oxidisation
t cut is not nice .hard work and messy
go to halfords and look thru meguiars range
deep crystal paint cleaner will do the job
john
Zayyan
Post Fri Feb 10, 2006 11:18 pm
10% of a bottle of Turtle Wax Colour Magic did this for my very pink car:
http://album.icbroadband.com/bits/car2.jpg
It was buy one get one free at Ԛ£6.99 IIRC, best 35p I've ever spent!
Jon wouldn't recommend it though so you should probably listen to him Image
320Touring
Post Sat Feb 11, 2006 4:18 pm
If the oxidation is REALLY bad, you can try a cutting compound called
G3 from any local auto paints store
if its basically just a bit pink the Jon's advice is spot on (see his car photo's as proof)
jamo
Post Sun Feb 12, 2006 10:28 am
My bonnet is pink (white in places) 2 of of the pannels rnt that bad, just a dull pinky red. Will try the megiars stuff. Have been embarased to post pic of my car as would look ropey compaired to the quality of everyone elses cars. :oops:
c76jon
Post Sun Feb 12, 2006 10:42 am
try the least abrasive stuff first
you can always work up to a coarser grade after
its dead paint that is lying on the surface of your piant
this is caused by uv rays
it suggests that the paint has not had sufficient coverage of a quality wax/polish/sealant in the past
make sure once you have it removed that you apply something that will protect it in the future or you will be back at square one
john
jamo
Post Sun Feb 12, 2006 10:47 am
Should i use g3 on the bonnet and meguirs on the panels?
c76jon
Post Sun Feb 12, 2006 10:56 am
my advice is to use the least abrasive first
if the meguiars does the trick then thats all good
if not then move up to a more abrasive product
no need to take more paint off than you need to
make sure you use quality microfibre otherwise you will put massive swirl marks into your paint surface
john
jamo
Post Sun Feb 12, 2006 11:00 am
Micro fibre? Please forgive my ignorance :? In the past when i have cleaned my car, its a bit of t-cut and wax, not really taken a lot of care....
c76jon
Post Sun Feb 12, 2006 11:05 am
ok no problem
microfibre is a type of cloth that is available in different weaves etc
these are then used to perform certain tasks
ie drying,washing,polish application and removal etc
if you use a top quality one they will not make any marks on your paint as you remove the oxidised paint and apply polish
if you look at many cars especially in the sunlight you will see swirl marks
these have been caused by application of products using cloths/rags that leave marks
sponges,chamois leathers and stockinette do the same
using good quality m/fibre will not leave these marks
john
jamo
Post Sun Feb 12, 2006 11:17 am
i get you, will ave a go, if it works and paint comes up nice, will post a few pics, (just to show i do actually have an E30) Thanks for the advice.
H-M3
Post Tue Feb 14, 2006 1:09 pm
c76jon wrote:my advice is to use the least abrasive first
john
John my car suffers from the same symtom. Should I just use the meguires stuff or clay then meg? I was looking at the catalouge it showed 3 steps for meguirs?? any tips? cheers buddy
Allan320
Post Wed Feb 15, 2006 6:57 pm
Well. If you werent in cardiff i would have helped you out, being a fellow bear and all ;)
jamo
Post Wed Feb 15, 2006 7:01 pm
Nice one mate, you get to many matches?
Allan320
Post Wed Feb 15, 2006 7:02 pm
Yeah I got a season ticket mate. Just looked at what ive got in my collection. You could try Autoglym paint renovator (halfords) and see how that brings the paint up.
Allan
jamo
Post Wed Feb 15, 2006 7:14 pm
Goin to have a go at the weekend see what happens? Its annoying as half the car looks spot on the other side looks shite, only good thing at the min, is the rain,cant really tell, but as soon as its dry....... Havent been to match in a while, used to go a lot when i was home in N Ireland, was in a gers supporters club. Bit depressing this year though, hoprfully get better when alex goes, new manager more cash. Goin to win the champpions league this year anyway, so at least we will have one trophy.... (well... maybe not, but its nice to dream)
superted
Post Sun Feb 19, 2006 9:02 pm
my brother did his 86 316 last yeay all by hand with t cut - took ages. he didnt want to use a buffer and compound incase he damaged the crome.
if its realy bad try flicking it down with 1500 wet n dry with plenty of soap and water - remember to use a rubber block - then buff it with g3 compound and wax straight away - do a panel at a time
if u cant get a buffer i guess its elbow grease time
the trick is to take your time and do small amounts at a time
ask me bro - took him 2 weeks in all - bit at a time
