Rear top mounts part number
Fal_325i
Post Wed Nov 15, 2017 2:15 pm
Hi
Just wondering if anyone happens to know the part numbers for the rear top mounts, car in question is a 325i convertible.
BenHar
Post Wed Nov 15, 2017 7:15 pm
Use E46 convertible top mounts. They are stronger.
Ben
320iConvertible
Post Thu Nov 16, 2017 5:31 pm
^^ Sure about this Ben, don't they need reinforcement plates ?
Post Thu Nov 16, 2017 6:11 pm
Ben's correct. They look identical to E30 ones in all dimensions, but the central steel bush is barrel shaped, rather than a plain parallel sided tube, so is much less likely to detach itself from the rubber.
The reinforcement plates are a Z3 part, IIRC, but I've never seen a need for them on any E30.
Fal_325i
Post Thu Nov 16, 2017 9:28 pm
Thank you, ay part numbers for these ?
Post Thu Nov 16, 2017 9:35 pm
33 52 6 779 670
Fal_325i
Post Thu Nov 23, 2017 8:11 pm
Thanks Brian, these be ok for a convertible I take it?
Post Thu Nov 23, 2017 8:21 pm
Fit all E30s, but, if fitting aftermarket dampers, a load spreading washer must be fitted underneath the mount. On OE dampers, the washer is part of the dust shroud, and often gets binned with the dampers..
Post Thu Nov 23, 2017 10:28 pm
E46 rear top mounts are all the same regardless of body shape or engine size
steve_k
Post Fri Nov 24, 2017 7:44 am
