Hi
Recently my fuEl gauge has become funny. Sometimes the needle just flicks back and forth so I don't know how much fuEl I have. Also the rev gauge also is not working. What can this be ??
Electrical gauge
- Stefan on probation
Could be the earth on the back of the cluster.
steve_k
- Contact:
^^^^^this, 8mm brass nut on the back of the gauge, tighten it up & it should work properly.SexyLady wrote:Could be the earth on the back of the cluster.
- Brianmoooore
That will most likely sort the fuel gauge, but is nothing to do with the tacho., or do you mean the econometer gauge under it?steve_k wrote:^^^^^this, 8mm brass nut on the back of the gauge, tighten it up & it should work properly.SexyLady wrote:Could be the earth on the back of the cluster.
If you mean the tacho., did it suddenly stop working on its own, or has any work been done to the car?
