Strong smell of fuel toxicating in cabin
aarc
Post Fri Oct 27, 2017 2:14 pm
Hi all ive got a strong smell of im not too sure what it can be most probably fuel coming into the car, in stand still traffic it can be sickening. Any ideas of what this can be I cannot see any visible fuel leaks and most the fuel likes look like they have been replaced on the car its a M20b20.
I hope to hear back from you guys soon
RB2
Post Fri Oct 27, 2017 2:40 pm
lifted the back seat to see whats under it?
Post Fri Oct 27, 2017 2:53 pm
Have a look under the bonnet for the high pressure fuel hose spraying fuel through a pin hole leak with the engine running. These can be extremely difficult to spot, but a clue that a leak is present is if the car takes somewhat longer to start than normal after being parked for a while.
aarc
Post Fri Oct 27, 2017 4:15 pm
Under the rear seat its all fine, fuel tank caps are in place as they should be. ok thanks Brian ill check for that but it start perfectly so highly doubt a leak so confused at this point any other suggestions guys?
tha881
Post Fri Oct 27, 2017 6:36 pm
Does it smell like exhaust fumes or raw fuel?
fixedwheelnut
Post Fri Oct 27, 2017 6:44 pm
Check the fuel hose connections at the Fuel rail and pressure regulator, these are prone to the rubber hardening due to heat and can leak when cold but seal up again as the engine warms up, provided it hasn't caught fire by then.
Have a good look under the bonnet with a cold engine start.
Post Fri Oct 27, 2017 11:27 pm
you don't want fuel spraying on the alternator
RIP 325i cab :eek:
Captain_Birdseye
Post Sat Oct 28, 2017 1:26 pm
Bloody hell, mine's got those symptoms.
paultv
Post Sun Oct 29, 2017 5:36 am
Do you have a breather return hose on the top of the fuel tank, right hand side ( looking from the back ) they often look fine but are split underneath where you can't see, usually enough slack to cut the end off and make good.
Just a thought
Paul :-)
AlexBarton
Post Mon Oct 30, 2017 3:40 pm
Brianmoooore wrote:Have a look under the bonnet for the high pressure fuel hose spraying fuel through a pin hole leak with the engine running. These can be extremely difficult to spot, but a clue that a leak is present is if the car takes somewhat longer to start than normal after being parked for a while.
^^^ that one if its really strong smelling and your MPG is terrible. my one was a leak out of there onto my exhaust manifold 8O, replaced that straight out as soon as that happened...
or if it seems to come from more the passenger side when your stationary, check the hose that comes from the fuel pump / tank that runs under the engine then up. had it replaced recently on my M20B20 touring when i'd had enough of trying to track it down after 6mths and got a garage to look at it
mikemike
Post Mon Oct 30, 2017 7:34 pm
had a similar problem a couple of months ago , it was a loose fuel pipe just above the thermostat , quick tighten of the screw problem fixed
Gert_8
Post Wed Nov 01, 2017 12:17 pm
Fuel filter leak under the car?
clipper
Post Tue Nov 07, 2017 10:57 am
If it smells even stronger around the filler cap area, suspect the vent pipe which connect to the top of the neck. They get brittle and come off.
