Hi, I have a 1987 e30 which has cruise control, I have owned thecar for the last 10 years and it did previously work, but it is no longer working is there anything I can do to repair myself. Any suggestions or advice will be greatly appreciated.
Thank you
Cruise Control
W111nyr
Anyone come across e30 with cruise control, urgent help needed please
Tedswagon
Hi there, I can't say I know anything about it but have a look in e30 wiki - the tab is at the top of the page. If you click on all wiki pages you can scroll down and see everything. I found this link in there. Good place to start I'd say.
http://www.e30zone.net/e30zonewiki/inde ... se_Control
Hope you manage to get it fixed.
The heart of the system is usually reliable so the problem is likely to be around the peripherals. Clutch switch would be the first thing to check out.
W111nyr
Hi, many thanks for the link I'll have a look at it tomorrow, and hopefully Ican get it fixed
W111nyr
Thanks Brian, i'll have a look into that
This circuit diagram may help: http://www.autolib.diakom.ru/CAR/BMW/19 ... /fig07.pdf
TriggerFish
I've had a A3 copy of that diagram printed out for a while now to try and get mine working too.
It looks like a fairly simple system, I figure it's just a case of pinning down where the signals stop with a multimeter (does it reach the ECU? Do commands reach the actuator?) and then replacing whatever proves to be faulty.
Partridge
My car came with it. Decided one day to make it work, went through the Wiki on here and soon discovered the dash had been changed and the green plug left out. Bought another, fitted and now works a treat!
The green plug and socket are a luxury anyway. The wire will just push into the hole on any cluster.Partridge wrote:My car came with it. Decided one day to make it work, went through the Wiki on here and soon discovered the dash had been changed and the green plug left out. Bought another, fitted and now works a treat!
