Exhaust Manifold stud broken
Nickerz
|Does anyone know what the thickness of the material around the studs are. As in how close are they to the water jacket. Will a m12 thread with an m8 thread insert be ok.?
jimmyspeed
well they often get helicoiled - which needs a larger tapped hole to fit the insert
why the jump from m8 - to m12?
With an internal thread of M8 x 1.25 the drill size is 8.3mm for helicoiling.
jimmyspeed
less than i thought, but after tapping its in essence like tapping a standard m9/m10 hole
biffer
When a garage repaired a broken stud on my NO.1 cyl., they ended up with a timesert screwed into a larger timesert so there must be a fair bit of metal around them?
It is indeed but the only other option is to circular mill the hole and weld an insert in which will not be cheep.jimmyspeed wrote:less than i thought, but after tapping its in essence like tapping a standard m9/m10 hole
