Help please Water weeping from head gasket
JagsK1981
Post Wed Sep 20, 2017 10:31 pm
Just rebuilt the engine, started all fine a few days ago, checked it today and noticed water weeping from the head gasket. The head was torqued to the required setting.
Any advice on what theis could be?
Thank you
aimlessrock
Post Thu Sep 21, 2017 8:57 am
where on the head is it weeping from ?=- need some photos.
assume you had the head pressure tested and refaced for the rebuild?
E30 320i Convertible (1989)
190 Mercedes (1988)
Post Thu Sep 21, 2017 9:34 am
Cheap gasket, head/deck face not clean, head face not flat or block deck not flat.
One or more of the above.
JagsK1981
Post Thu Sep 21, 2017 11:05 am
Ok guys thanks for the advice, it has been tested and all done. The gasket was from euro car parts so may be that. Thanks for the advice will update on how I get on.
Post Thu Sep 21, 2017 3:56 pm
Maybe try re-torqueing the head bolts again - sometimes they need re-tightening after the gasket has settled.
JagsK1981
Post Thu Sep 21, 2017 4:38 pm
Ok thanks you will try that tonight
Post Thu Sep 21, 2017 9:17 pm
Speedtouch wrote:Maybe try re-torqueing the head bolts again - sometimes they need re-tightening after the gasket has settled.
Not really practical with stretch bolts.
JagsK1981
Post Thu Sep 21, 2017 10:26 pm
This is a strange one, checked where the leak was and there’s no water leak. Will have to keep an eye on it over the next few days
Thanks for all the advice so far guys
Post Fri Sep 22, 2017 9:16 am
Sometimes, they will initially weep a little, then once surface rust/corrosion has taken place, they re-seal themselves...
JagsK1981
Post Fri Sep 22, 2017 9:18 am
Speedtouch wrote:Sometimes, they will initially weep a little, then once surface rust/corrosion has taken place, they re-seal themselves...
Thank you I hope that’s what has happened
