hi all how to post images.. rust trap
arrisbmw
Post Fri Sep 15, 2017 5:08 pm
[img]how do i post images on here.
thanks [/img]
arrisbmw
Post Fri Sep 15, 2017 5:14 pm
hello
M3KUK
Post Fri Sep 15, 2017 6:34 pm
I used to use Photobucket, but they charge now. The Forum is working on picture hosting at the moment.
Post Fri Sep 15, 2017 7:04 pm
Instructions are in stickies at the top of the for sale forums, but as M3KUK says, there's a revamped forum coming in a few weeks, which will have pics. included.
arrisbmw
Post Fri Sep 15, 2017 8:07 pm
o.k cheers . sounds better to wait.
arrisbmw
Post Mon Sep 18, 2017 11:54 pm
just found a rust trap on my E30. .. was gonna put some pic on here but looks like I,ll upload em when forum is vamped.
FYI
If you look under rear wheel arch off side towards the filler cap, your see a badly fitted in my case, half plastic splash guard, held on by 4 nuts/bolts remove this , and mine was full of caked mud and crap . Hose all out leave 24 hrs, and get the rust treatment out. I think the s/g was doing more harm than good by trapping the mud in there. Once I,ve treated my rust gonna refit the s/g but probably with some sealant on the edges to stop the crap getting in.
your understand if you look.
Tedswagon
Post Tue Sep 19, 2017 7:01 am
That sounds like a good plan. If possible you should consider using a wire wheel to clean the rust off. Get it back to bare steel, then rust treatment, then seal.
I use Bilt Hamber, detox gel for rust treatment. See here, https://www.bilthamber.com/deox-gel
Post Tue Sep 19, 2017 1:15 pm
So, who is good for image hosting in the short term ?
Stefan on probation
Post Tue Sep 19, 2017 1:25 pm
I used https://imgbb.com at least you get a link to post up.
Post Tue Sep 19, 2017 1:38 pm
The wedding car this year
My first 330 se
Postimage is the host and stupidly quick to join
