Convertible water into hood storage
Bally
Post Fri Aug 04, 2017 11:01 am
Hi I have a 1992 convertible the bit under the horse shoe fills up with water and just sits there have to sponge it out any ideas what would cause this is there any drainage here or should water not be getting in only thing I can think of is the rubber seal for horse shoe any help appreciated thanks
paultv
Post Fri Aug 04, 2017 11:16 am
Water is supposed to get into the area and then drain out.
There are two drainage holes at the lowest point where the roof hinges are bolted to the floor of the stowage area - usually full of crap and blocked. Also the drains from inside the rear window stowage area to the sills are also partially blocked as well. Removing the rear inner side panels and rear window units gives good access to clean all of this up - essential if you don't wan to watch your cabby rot away from the inside.
Paul :-)
Topblag
Post Fri Aug 04, 2017 11:47 pm
paultv wrote:Water is supposed to get into the area and then drain out.
Paul :-)
Have to disagree. The seal around the horse shoe is supposed to keep water out, the drain holes are to cope with a failed seal. Horse shoe seals are either NLA or very expensive. Get a good one from a breaker.
But as above, make sure those drain holes are clear also.
1984 Hartge H35 in Black
2006 Audi S6 V10 in Black 58k
Bally
Post Sat Aug 05, 2017 3:43 am
Thanks for advise will have a go
torquey
Post Sat Aug 05, 2017 12:47 pm
I have just replaced my horseshoe seal and boot seal,both from bmw for around £100.
Topblag
Post Sat Aug 05, 2017 1:22 pm
torquey wrote:I have just replaced my horseshoe seal and boot seal,both from bmw for around £100.
Each ?
paultv
Post Sat Aug 05, 2017 1:24 pm
There is a 5mm gap between the horseshoe and the window escutcheon allowing easy access for plenty of water off the roof, even with a new rubber - which is widely available from BMW, Leebmann, EBay, Pelican etc etc
Also at this point the rubber is flat and doesn't stop water ingress at all - just badly designed - but if your drains are clear then no issue at all.
http://whitewatermedia.net/media/horseshoe.jpg
http://whitewatermedia.net/media/horseshoe%202.jpg
Paul :-)
Bally
Post Sat Aug 05, 2017 1:40 pm
Had a look dried out but could no see any drain hole I'm looking where the roof bars are attached to the body near the rear quarter
paultv
Post Sat Aug 05, 2017 2:00 pm
They are on the outer face - and a bugger to find if full of crap - I'll see if I can get a photo -
http://whitewatermedia.net/media/drain.jpg
image of Near Side drain
here ya go
Paul :-)
mikemike
Post Wed Aug 09, 2017 7:31 pm
had the same problem a few years ago , found on you tube how to clear the drain holes using a piece of brake pipe to guide a length of strimmer line into the drain hole and out to the sill , its a bit of a fiddle but it works
