Removing residue of underbonnet deadening foam
Post Thu Jul 27, 2017 8:34 pm
I am going to be replacing the sound deadening foam from under bonnet as it has rotted and become crumbly.
I have removed as much of the foam as I can but has still left the remains of the sticky film. What is the best way to remove this film without scratching the paint. Can it be removed by any solvent or with gentle heat?
steve_k
Post Thu Jul 27, 2017 8:36 pm
Try autoglymm intensive tar remover l.
I used it on a wing after stripping it of vynal wrap, took a bit of elbow grease but it did the job.
Post Thu Jul 27, 2017 8:41 pm
Many thanks for the prompt reply. I will have go.
steve_k
Post Thu Jul 27, 2017 8:42 pm
No worries, be warned your hands/fingers Will be sore afterwards
Cloggy Saint
Post Thu Jul 27, 2017 8:57 pm
Don't waste your time shifting the old glue residue, just stick the new foam over the top, it'll hold just fine.
Stefan on probation
Post Thu Jul 27, 2017 9:39 pm
bss recomendad some Toyota brake or clutch fluid years back can't remember which it was though.
Topblag
Post Thu Jul 27, 2017 10:15 pm
Spray on brake cleaner and a plastic scraper, unless you want to risk scoring into the paint underneath. Replacements stick much better onto a properly clean surface.
Do in a well ventilated area, fumes from brake cleaner are strong :mad:
1984 Hartge H35 in Black
2006 Audi S6 V10 in Black 58k
Post Thu Jul 27, 2017 10:19 pm
SexyLady wrote:bss recomendad some Toyota brake or clutch fluid years back can't remember which it was though.
May not be brake fluid as this will act like paint stripper!
peterjcollins
Post Sun Jul 30, 2017 8:19 pm
Wear good gloves to protect your hands,cover the engine with an old blanket and use a cloth soaked in a petrol.
This was the best way to remove the old adhesive
Cloggy Saint
Post Sun Jul 30, 2017 8:28 pm
Or again, don't bother.
Topblag
Post Sun Jul 30, 2017 10:19 pm
peterjcollins wrote:Wear good gloves to protect your hands,cover the engine with an old blanket and use a cloth soaked in a petrol.
Much easier just to take the bonnet off and lay it flat.
