Anyone have a good solution to keep cab horseshoe cover down
PeteE30Tourer
Post Tue Jul 18, 2017 8:10 pm
As per the title... the electrics for my cab hood gave up the ghost long ago and I'm quite happy to put the hood up and down manually, but I can never get the horseshoe cover to clamp down tight, so it rattles constantly. Currently, I have a pair of mole-grips on the shaft of the mechanism in the boot that I can turn to pull on the bowden cables, then lock it in place with the motor, but it's a faff and as I said, never really works.
I was thinking of putting a couple of toolbox type latches, one either side inside the cabin, but there doesn't seem to by much in the way of secure metalwork to screw these into.
Any other bright ideas or proven solutions?
Back behind an M20, but now I can hear it better.
Stefan on probation
Post Tue Jul 18, 2017 10:28 pm
Retrofit the manual horseshoe locking mechanism.
PeteE30Tourer
Post Wed Jul 19, 2017 8:15 am
Hmmmm - didn't realise there was such a thing to be honest. Is there a kit of parts available to do this?
Stefan on probation
Post Wed Jul 19, 2017 9:51 am
Convertibles with a manual roof have these fitted like in mine, on the passenger side under the rear speaker cover do you have a cut out/handle?
PeteE30Tourer
Post Wed Jul 19, 2017 8:14 pm
No existing cut out or handle, but I found an informative YouTube video showing how the manual kit is retrofitted. Thing is, getting hold of the parts necessary. Been to BMW today and they don't sell them. Looks like I'll have to find a breaker.
Thanks for the suggestion.
M3KUK
Post Wed Jul 19, 2017 10:05 pm
You can lock it down using the Z shaped allen key thingy in the tool tray.
There is a hole in boot panel it fits into.
That's what I do, my roof is electric but is currently not working.
PeteE30Tourer
Post Fri Jul 21, 2017 5:12 pm
I think I know what you mean, but I've already exploited that option - a previous allen key broke off in the middle of the shaft that's turned to clamp down the cover, hence the use of mole grips as an alternative.
M3KUK
Post Fri Jul 21, 2017 6:00 pm
Right, if you are going full manual you will have to locate the manual handle etc. I don't know how it works in manual because I am Semi Auto!
dave525
Post Wed Jul 26, 2017 12:39 pm
the manual mechanism is simple. Its 2 catches,2 cables,a handle and a safety catch. best got complete from a breaker.I retrofitted one to mine.
corkie
Post Wed Jul 26, 2017 1:43 pm
Cable ties !youre welcome !
e30
Stefan on probation
Post Wed Jul 26, 2017 2:19 pm
corkie wrote:Cable ties !youre welcome !
Post your photos up then.......
PeteE30Tourer
Post Wed Jul 26, 2017 3:38 pm
dave525 wrote:the manual mechanism is simple. Its 2 catches,2 cables,a handle and a safety catch. best got complete from a breaker.I retrofitted one to mine.
Thanks Dave. Looks easy enough, but at least I know where to go now if I need some advice!! Kit of parts required obtained through someone on here, so should be getting on with this early next week hopefully.
Loved the cable tie suggestion Corker, but I was looking for something a little less permanent!
Stefan on probation
Post Wed Jul 26, 2017 3:55 pm
PeteE30Tourer wrote:
Do you have a chubby/fat girlfriend?
corkie
Post Wed Jul 26, 2017 6:06 pm
I do she 6 months pregnant a˜€
e30
Stefan on probation
Post Wed Jul 26, 2017 7:35 pm
Get her to sit on it then........ :twisted:
j4gz
Post Wed Jul 26, 2017 8:08 pm
HI i know a guy who had the same prob as your are facing he used these https://www.ebay.co.uk/i/252327407203?c ... 929&crdt=0 on the actual horshoe cover on the outside itself attached to the other to the moulding from what i can remember ...
PeteE30Tourer
Post Thu Jul 27, 2017 9:04 am
That's exactly what i was originally looking at, but I couldn't find anywhere to secure them to both the horseshoe and the interior of the car that was strong enough to take the force of locking these down.
Hopefully I'm sorted now with a kit of parts to convert to manual coming in the post shortly.
Thanks for all the suggestions folks.
PeteE30Tourer
Post Thu Jul 27, 2017 9:05 am
Sorry - missed this suggestion! I do have a wife, but I wouldn't call her chubby or fat. Not sure it would do her hair any good either bombing around sat on the cover!!
Quaser
Post Thu Jul 27, 2017 9:31 am
Forget all that - when I had this issue on my cab, I wired up a 2 way switch direct to the horseshoe motor (I think I used an electric window switch and put in where the ac switch goes)
Then you simply press the up button to unlock it, and down to lock!
M3KUK
Post Thu Jul 27, 2017 6:38 pm
That's a brilliant idea thanks! I will use it on my roof.
PeteE30Tourer
Post Fri Jul 28, 2017 6:48 pm
Quaser wrote:Forget all that - when I had this issue on my cab, I wired up a 2 way switch direct to the horseshoe motor (I think I used an electric window switch and put in where the ac switch goes)
I had considered this option as it's how it all worked when i bought the car, but something stopped working and I gave up on trying to fix it.
PeteE30Tourer
Post Fri Jul 28, 2017 6:53 pm
Hi Dave, as expected, I have a query having retrofitted most of this kit to my car today. It's about the "safety catch" - where does this bolt on to and what does it "catch", i.e. do I need a secondary hook for it to latch on to, or does it latch on to one of the existing two hooks?
Here's a link to all the parts - http://www.realoem.com/bmw/enUS/showpar ... Id=41_0805
I'm querying whether I need part 3?
Stefan on probation
Post Fri Jul 28, 2017 7:08 pm
On the passenger side of the horseshoe do you have a sticky out bar with a rubber bit on the end welded to it just behind the U shaped bits if you get my drift.
The safety catch attaches to the inner side of where the roof folds in to. If needed I can take some photos tomorrow for you.
PeteE30Tourer
Post Fri Jul 28, 2017 7:32 pm
SexyLady wrote:On the passenger side of the horseshoe do you have a sticky out bar with a rubber bit on the end welded to it just behind the U shaped bits if you get my drift.
Crikey - you're always on the ball aren't you! Thanks for the prompt response and offer of help.
I cant see any such sticky out bar - I've taken a photo to show what I do have:
Am I missing a sticky out bit???!!
Stefan on probation
Post Fri Jul 28, 2017 8:05 pm
Yep, looks like it.
Let me get a photo of it tomorrow I had one but deleted it off my iPhone.
The thing is it will lock in place with out it between you open the horseshoe you can just pull it up without un hatching the safety mechanism.
Stefan on probation
Post Fri Jul 28, 2017 8:10 pm
Always happy to help the younger generation and have messed around with my roof enough times and now have a decent one that needs no more work done to it.
PeteE30Tourer
Post Fri Jul 28, 2017 8:40 pm
Thanks - I'd really appreciate a photo of what your's looks like. If it's welded to the horseshoe insides, I guess I'm buggered, though I may be able to fabricate something that does the same job.
Having ordered the safety catch from BMW (collecting it tomorrow), I'd like to be able to fit and use this. If possible, I'd like to see how this secondary catch bolts on too as it's not clear from the RealOEM diagram you kindly provided.
Stefan on probation
Post Fri Jul 28, 2017 8:48 pm
Your not totally buggered as to be honest you could get away without the safety catch, mine has never opened u on it on in the last 6 years.
I did a search on google and can't find an example and the photos I had on my phone I deleted as I thought you where sorted, grrrrrrr
PeteE30Tourer
Post Fri Jul 28, 2017 9:10 pm
I guess you're right - having seen how the main two catches work, I cant see them both coming undone and releasing the cover. I dont ever have anyone in the back to accidentally operate the handle - only the dog, and although she's a smart pup, she's not that clever!
Sorry for the hassle with the photo :(
Stefan on probation
Post Fri Jul 28, 2017 9:15 pm
No worries if you have the bits you may as well fir them and if you ever sell the car you can state that its been converted I think the little bar you could make ruer self and all it need is a couple of spot welds or buy the right horse shoe and sell yours but it may not be worth the hassle.
Give me a day or so and I'll get some photos just need to get the car out of the garage unless my son pops around tomorrow and I abuse his ;o)))
PeteE30Tourer
Post Sat Jul 29, 2017 12:17 pm
SexyLady wrote: Always happy to help the younger generation and have messed around with my roof enough times and now have a decent one that needs no more work done to it.
Younger generation??!! I wouldn't put myself in that bracket! I'm an old timer!
Anyway, been down A&E this morning as the horseshoe fell on my hand yesterday and it's all swollen up today and I cant use my right thmb. Nothing broken thankfully.
dave525
Post Tue Aug 08, 2017 1:33 pm
Sorry ive been away.The safety catch is just that. if the 2 main catches work you don't have to have it.I will have a look at mine,i cant remember what it clips to
PeteE30Tourer
Post Tue Aug 08, 2017 1:50 pm
dave525 wrote:Sorry ive been away.The safety catch is just that. if the 2 main catches work you don't have to have it.I will have a look at mine,i cant remember what it clips to
Thanks Dave, apparently there's a bar or something welded on to the inside of the horseshoe itself, which I curiously don't have, suggesting there were two variants of the horseshoe itself. I've fitted the safety catch just because I'd already bought it from BMW, but will look into fabricating something that this latch will catch, if you see what I mean.
Stefan on probation
Post Tue Aug 08, 2017 4:20 pm
I will try to get a photo for you tomorrow of the bar.
Stefan on probation
Post Tue Aug 08, 2017 4:55 pm
Try clicking on these links
https://ibb.co/dungMa
https://ibb.co/iH5qEv
