Hello there.
Planning to use an oil cooler on my Euro M50B25 (non-vanos)
I'm going with the option of using an Euro S50/S54 oilfilter housing with standard oil cooler connections .
I thought this would be a straight fit, but some say this doesn't fit. After searching on this forum, some say I need other parts to make the S50 housing fit. But I can't work it out
Anyone in for help?
S50 oilfilter housing fitting issues
Quaser
its a straight fit - you need to drill out the ports a bit to get the screw type connectors on there, and you need a m50 power steering pump
