This is probably the roughest thing Iv considered in a long time hence why I thought I'd ask as I'd rather not be killed.
I have picked up a set of wheels and semi slicks to run on my car with an agressive offset etc so I cannot afford to run spacing. Unfortunately the caliper carrier bar does not clear the hub of the wheel.
I have done some research etc and shaved a fairly heroic amount off of this to the point im not overly confident in it. I have however, done some research and with my own knowledge knowing that an e36 caliper for eg, does not have a carrier bar, would it be possible to remove the one off an e30 caliper safely or would this result in snapping?
I can upload pictures if this would help, however I basically see a few options
1: balls to the wall cut the bar out as online suggests it is mainly for manufacturing process and low stress, and many vehicles have carriers without them.
2: throw money at a big brake kit I intended on in the future to allow for extra clearance.
3: find some new wheels and possible have a similar issue again anyway.
Brake carrier bar removal?
verde
Raise hell praise Dale.
Tedswagon
I can't picture how the bar is fouling. Could you post a pic?
maxfield
I've seen calipers/carriers shaved to accept wheels.
There's plenty of metal to trim off.
Pictures would help.
verde
This is basically why spacing is no option
And you can see here how much I have already shaved off, there aint much left!
But the e36 for EG does even have a bar, it does however have a rattle clip
verde
Well I went balls to the wall and cut the bracket but it still catches on the pad anyways so I will be looking for a BBK. Which I feel more comfortable doing anyway as I had visions of something going catastrophically wrong coming down Cairn O mount.
For anybody hoping to install Grids on 325 brake set up without spacers....You cant.
