Front wheel bearing
chinna
Post Fri Jun 23, 2017 9:46 am
Does anywhere sell the front wheel bearings on there own or is it the hub and bearing only
Sanchez
Post Fri Jun 23, 2017 9:49 am
Front is hub and bearing, rear is just bearing.
chinna
Post Fri Jun 23, 2017 10:05 am
No problem. Just ordered 2 Febi. Hopefully ECP won't feck up and will get them in for tomorrow. Thanks for the quick reply.
Doobit
Post Sat Jul 01, 2017 3:34 pm
Have to fitted your bearings yet. I have to replace the font wheel bearings on mine. was it an easy job?
E30 325i Cabriolet Alpinweiß chromie
F12 640d
G11 730d
gromgsxr
Post Sat Jul 01, 2017 6:44 pm
When i did mine it was a easy job bearing just pulled off the stub with hand power but i may have got lucky there.
Grzesiek325i
Post Sat Jul 01, 2017 6:48 pm
Inner ring can stuck on shaft but bearing splitter it's not expensive tool
Doobit
Post Sun Jul 02, 2017 9:51 am
Thanks guys. I'll try it myself.
F12 640d
G11 730d
TriggerFish
Post Sun Jul 02, 2017 12:16 pm
Grzesiek325i wrote:Inner ring can stuck on shaft but bearing splitter it's not expensive tool
Mine did this - just removed the brake back plate and used a smaller puller to get the inner ring off.
My local ATS even let me use their torque wrench as I've misplaced my decent one during a house move, and could only get it to 170lb/ft accurately.
Doobit
Post Sun Jul 02, 2017 8:18 pm
Thanks guys, so far so good. Needed me and the missus standing on a breaker bar to loosen the axel shaft nut, which was quite romantic. And the brake caliper nuts were a bugger to get undone until the WD-40 soaked in.
F12 640d
G11 730d
aimlessrock
Post Mon Jul 10, 2017 1:59 pm
Doobit wrote:Thanks guys, so far so good. Needed me and the missus standing on a breaker bar to loosen the axel shaft nut, which was quite romantic. And the brake caliper nuts were a bugger to get undone until the WD-40 soaked in.
Having an + sized wife really helps in situations like this- armed with a breaker bar there are few bolts that will not yield under such pressure..
essential for any resto ;-)
E30 320i Convertible (1989)
190 Mercedes (1988)
