Hi
I have looked at past posts. I have a 391 lsd and was thinking of trying it in my e30 s50 . Would it be worth it or would 2 gear be like 1st so on think I have 364 at the minute and had it on rolling rd 279 bhp topped out 133 mph any one tried this many thanks
Diff
I'd an uprated Medium case LSD 3.45 ratio in my s50b30, with the 5 speed box in my old compact. It happily went to 120 before the end of the straight at knockhill. Would have gone faster if the straight was longer, but would have been better if was quicker out of corners imo.
Not sure if that helps.
- Brianmoooore
What's first gear like at the moment? Fully usable or unsticks the tyres at the slightest press of the throttle?
The diff. change is between 7% and 8%, whereas the change from 1st to 2nd gear is over 40%, so it's not going to change 2nd to another 1st.
- Brianmoooore
E30 prop has a sliding section on the rear section. Clamp nut is just behind the centre bearing.
Looks like this might be a small case diff. though, which might not take kindly to the torque from a S50 donk.
How many bolts hold the rear cover in place?
Seen on the wiki page yep have a medium case diff 8 bolts was told out of e30 325 sport 391 lsd . One that in is a 338 6 bolts think out of e36. Which is ok handles the power. It has e36 gearbox 2.8 . Wiki page saying can only move prop 10 m so if it still to short do a buy e36 prop cheers
