Quick Question - LSD
Stefan on probation
Post Tue Jun 13, 2017 1:18 pm
Would anyone fit one to an automatic, the spec sheet says one was fitted but the tag on the diff has corroded so can't confirm?
jimmyspeed
Post Tue Jun 13, 2017 4:22 pm
could still be a slipper -
To identify an LSD one can first check for the presence of the tag on the rear casing. The ratio on this will be prefixed with an S for LSDs.
Alternatively one can jack up one rear wheel, ensure the car is out of gear and hand-brake is off then turn the raised wheel. Resistance on that wheel would usually indicate an LSD. An alternative method is to try to leave skid-marks pulling away on good tarmac, two tyre marks for more than a few inches would indicate a properly "locking" LSD. This won't work so well on grass or gravel as on loose surfaces both wheels can slip easier even for non-limited slip differential types.
Post Tue Jun 13, 2017 5:24 pm
Or jack up both rear wheels and rotate one; the other will rotate in the same direction if it's an LSD, or the opposite direction if it's an open (normal) diff.
