Hi
Does anybody out there know of a center cap that will just lock into the bore of the 15" BBS Wheels when not using the standard center caps ?
Alternative to centre caps
You could try aerosol can lids, sprayed silver (some are already pre-coloured), held in with some silicone sealant or similar...
- BHadley
- Contact:
If you have centre caps this method is like a fixed lock after the OE type to stop them vanishing....
http://www.mx5nutz.com/forum/index.php?showtopic=190489
Cloggy Saint
I've done this, it's a good deterrent but obviously anyone armed with an allen key can still take them. Don't drill the holes from the inside of the cap as per the write up, do it from the outside for a neater finish.slideout318i20 wrote:If you have centre caps this method is like a fixed lock after the OE type to stop them vanishing....
