M40b16 to M20B25 swap
chri
Post Thu May 11, 2017 5:58 pm
Hi all I m in the middle of this swap and like to clarify:
Do the M40 316i fuel pump feed the thirsty M20 325i?
jmc330i
Post Fri May 12, 2017 6:15 am
Yes, no problem.
James
'91 325i Sport
'93 318i touring 16v
chri
Post Fri May 12, 2017 5:56 pm
Thanks for the reply jmc
Another question
What are the 2 wires connected to the positive battery terminal?
On the M20 body there are still 2 wires while On the M40 body I ended up with only 1 wire because the other wire comes out with the harness
Post Sun May 14, 2017 11:56 pm
M20 and M40 should both have at least two wires going to the battery + terminal, in addition to the large cable to the starter motor. One of these feeds the engine wiring loom, and the other is the power feed to the fusebox and ignition switch.
There will be a third wire on cars with ABS, that powers the ABS pump motor.
chri
Post Mon May 15, 2017 9:01 pm
The extra wire as brian said was for the abs pump. Now sorted and engine started today and running perfect
love the 6 cylinder melody......
With some help from this forum the swap was a breeze
Thanks guys keep up the good work
