Leaky fuel tank
Bazo187
Mon May 01, 2017 4:53 pm
I own a 318i cab 1992
My fuel filler kneck was rusted out so changed that but disturbed the part where it connects to the tank.
Now that is leaking was wondering where the best place to get a fuel tank would be. Also how much should it cost me to changed from a garage.
darkchild
Mon May 01, 2017 7:23 pm
I bought one of these a couple of years ago and it's decent quality and fitted well. Quick delivery from Germany as well.
http://www.ebay.co.uk/itm/PETROL-DIESEL ... SwzaJX9leA
HartgeH27
Mon May 01, 2017 7:25 pm
These are good tanks but you will need to paint and put sealant over the tank.
Brand new available for around £180 but depends if you have 55 or 64 litre tank.
Guessing around 3 to 4 hours labour.
Bazo187
Tue May 02, 2017 9:49 am
Nice one boys
liamobzr
Tue May 02, 2017 11:27 pm
HartgeH27 wrote:These are good tanks but you will need to paint and put sealant over the tank.
What paint and sealer is recommended? I'm in the same boat with a leaky tank
mikemike
Mon Jul 31, 2017 8:24 pm
I had the same problem a couple of years ago , a replacement steel tank was around £800 , I found on ebay a guy who supplies plastic tanks for around £145 including delivery , comes with seals as well , make sure you get the right size tank as there are 3 different sizes , I think the convertible is a 65 litre tank , hope this helps
liamobzr
Tue Aug 01, 2017 12:02 am
mikemike wrote:I had the same problem a couple of years ago , a replacement steel tank was around £800 , I found on ebay a guy who supplies plastic tanks for around £145 including delivery , comes with seals as well , make sure you get the right size tank as there are 3 different sizes , I think the convertible is a 65 litre tank , hope this helps
Any links?
mikemike
Tue Aug 01, 2017 8:54 am
have a look on ebay for atp-spareparts . as before make sure you know which size tank you need as there are 3 different sizes , will try and add a link but normally when I try some thing like that it ends in a disaster . looking at a reply you had in may the link to spareparts is there , cheers from mike
