m10 upper sump help
sadham
Post Sun Apr 30, 2017 8:32 pm
M10 upper sump removal?
Got the lower sump off but struggling a bit with the upper sump. Where can I jack the engine from at the bottom to give me space for the bolts? The steering rack/ subframe Is in the way.
Anyone got any advice that could be useful to me?
Post Sun Apr 30, 2017 9:41 pm
Put the lower sump back on, undo the engine mount rubbers from the alloy mounting arms, jack the engine up with a piece of wood under the sump to spread the load, insert wedges/spacers between the mounts and the arms, lower jack, remove lower sump again and remove upper sump.
sadham
Post Sun Apr 30, 2017 9:46 pm
Undo engine mounts completely off or just loosen to the end?
Any ideas what I can use as a spacer? Maybe more wood blocks?
