Clutch resovior pipe?
Sanchez
Post Sun Apr 23, 2017 7:55 pm
Hi guys,
Need to replace the flexi pipe from the bottom of the clutch resovior tank to the slave cylinder above the pedal.
Question is does it just pull of though the bulk head into the engine bay? Couldn't see 100%
reggid
Post Mon Apr 24, 2017 5:13 am
there is small plastic elbow, one end goes into the master cyl and the hose slips over the other end of the elbow. be gentle with it as they can be a bit brittle with age.
it just pulls off, passes through a grommet in the firewall
http://www.realoem.com/bmw/enUS/showpar ... Id=21_0004
E30 325is with M20B31
Sanchez
Post Mon Apr 24, 2017 9:08 am
Many thanks.
