S50 or M60
jmc330i
Thu Mar 02, 2017 1:37 pm
So I've been considering another engine conversion recently. My Sport previously had an S50 fitted and I really miss it so I'm leaning towards doing another one, but I've also got the need for a V8 in my life!
Considering the cost of the M60 manual gearboxes or the S50 engines, plus the manifolds for either, I can see the overall costs being quite similar.
I guess the M60 is more involved what with the brake servo issue, I'd possibly build an M62 bottom end with M60 heads etc (I do enjoy the work as much as the finished project) and as I've already done an S50 I know what's involved with that, so I'm torn between the two.
Anyone got any thoughts? 8)
James
'91 325i Sport
'93 318i touring 16v
Thu Mar 02, 2017 1:39 pm
For me it would be a choice as follows
Road car V8
Track slag S50
jmc330i
Thu Mar 02, 2017 2:12 pm
Pretty much what I was thinking Dan. This will be a road car so the V8 would be more suited for a more relaxed drive, with the extra grunt when needed.
James
'91 325i Sport
Thu Mar 02, 2017 7:24 pm
is anyone running a V8 one with something that resembles brakes and having a glovebox or a car that stops?
jimbom30cab
Tech 1 freak
Thu Mar 02, 2017 9:18 pm
V8 would be more fun. Brakes would be quite expensive i would think.
KW355
Thu Mar 02, 2017 11:18 pm
I am running a wilwood bias pedal box, i have just added a remote servo on the fronts, it stops fine with the current e46 m3 brake setup but i am upgrading to 840 Brembos .
jmc330i
Fri Mar 03, 2017 9:33 am
Simon13 wrote:is anyone running a V8 one with something that resembles brakes and having a glovebox or a car that stops?
That is something I'm looking into. I've got an idea but need to do some measuring to see if it might work. If not, I'm not too worried about losing the glovebox - I can't actually remember the last time I opened the glovebox on either of my E30s.
James
'91 325i Sport
Fri Mar 03, 2017 12:08 pm
Rather than move servos and fluid reservoirs into the car, make the glovebox horrible and mess with linkages that introduce more flex into the thing I would use a proper pedal box like so - http://www.r3vlimited.com/board/showthread.php?t=341516
jmc330i
Fri Mar 03, 2017 1:53 pm
Thanks Dan :thumb: I don't know anything about pedal boxes, can you match the cylinder sizes to give a decent pedal for a road car?
James
'91 325i Sport
Fri Mar 03, 2017 6:46 pm
From what ive looked at it seems quite easy to get pedal effort below 20kg to achieve a 1g braking force, pedal ratio and master cylinder sizing dependant.
I will be fitting one of those Tilton setups to my track car soon 8)
Fri Mar 03, 2017 7:39 pm
An S38 engined e30 does the same job in an e30 like the V8 does from my experience, granted S38 engines are alot more money now. But when you could get a fucked 3.6 e34 M5 for £1500 it was as cheap a conversion as the v8's in fact cheaper and you could still have a novelty item such as a brake servo!
I drove Karans old 3.6 and it really did fly, a 3.8 would really fly as they pull a heavier e34 along really quite well
Fri Mar 03, 2017 9:06 pm
I seem to remember a zoner who had a dolphin grey 2dr tech 2 with an M6x V8 coupled to an auto box and he span at santa pod going up the strip.
He was a south african chap and i seem to remember (after looking round it prior to said spin) that it had the hydraulic booster set up as red in an E32/E34/big six E28 which negated the problem of servo size.
ajay
Fri Mar 03, 2017 11:11 pm
The fella with the white S38 touring you & Simon had a look under the bonnet at Ace cafe last year,is also a south African chap...a˜†
Sat Mar 04, 2017 8:35 am
bss325i wrote:I seem to remember a zoner who had a dolphin grey 2dr tech 2 with an M6x V8 coupled to an auto box and he span at santa pod going up the strip.
I remember that one, coolant hose blew off and greased the track, he span and made an epic save, then got a load of abuse from the commentator for driving to the end of the strip dropping coolant :D
KW355
Sat Mar 04, 2017 5:01 pm
jmc330i wrote:Thanks Dan :thumb: I don't know anything about pedal boxes, can you match the cylinder sizes to give a decent pedal for a road car?
I ran 5/8 wilwood masters on my pedal box with a 6.25 to 1 pedal ratio. I now believe i had a faulty master cylinder on my fronts as i could get 900 to 1500 psi on the rears by adjusting the bias but only 700 to 1000 psi on the fronts.
on non servo systems you need to go smaller with the masters to get higher line pressures.
I now have a 3/4 master on the fronts which now makes 1200 p.s.i or 1600 psi with the in line servo working.
The brakes now work much better than before but i am still fitting some 4 pot brembos on the front as well.
jmc330i
Sun Mar 05, 2017 8:58 am
Simon13 wrote:An S38 engined e30 does the same job in an e30 like the V8 does from my experience....
While I do understand what you're saying, if i was to go for an S engine again I would do another S50 conversion. I was more than happy with how it performed and considering I drove it as a daily driver for 12 months, it's mpg figures were pretty good - far better than the M20!
My Sport won't be a daily driver from now on, so I can go for something a little different and not have to worry too much.
James
'91 325i Sport
jmc330i
Sun Mar 05, 2017 9:04 am
bss325i wrote:it had the hydraulic booster set up as red in an E32/E34/big six E28 which negated the problem of servo size.
I'm glad you mentioned that Barry, it is one of the options I'm considering after seeing Ian's S50B32 with the same setup.
It may still need the mounting of the master cylinder moved towards the passenger side (as some move the servo for 24v swaps) to give more clearance to the head, but that's something I'll look into if I do go the M60 route.
James
'91 325i Sport
glenn
Engine Transplant Services
Sun Mar 05, 2017 9:07 am
bss325i wrote:He was a south african chap and i seem to remember (after looking round it prior to said spin) that it had the hydraulic booster set up as red in an E32/E34/big six E28 which negated the problem of servo size.
i used the hydraulic booster set-up from an e32 when i fitted the s62 into the warsteiner rep. had to find places to mount valves and an accumalator....
(only pic i could find)
jmc330i
Sun Mar 05, 2017 9:15 am
How does the pedal feel without the inline servo?
I've only driven a track built Mk2 Escort with a pedal box and pedal was far too hard for my liking. It may of been fine when pushing it around a track, but I certainly wouldn't want it like that for a road car.
James
'91 325i Sport
jmc330i
Sun Mar 05, 2017 9:17 am
DanThe wrote:From what ive looked at it seems quite easy to get pedal effort below 20kg to achieve a 1g braking force, pedal ratio and master cylinder sizing dependant.
I'd certainly be interested in how you get on with that Dan :D
James
'91 325i Sport
jimbom30cab
Tech 1 freak
Sun Mar 05, 2017 9:27 am
Would you consider the S54 engine ?
jmc330i
Sun Mar 05, 2017 10:27 am
jimbom30cab wrote:Would you consider the S54 engine ?
Possibly Jim, although I actually prefer the 'older' look of the S50 and think it suits the E30 engine bay better.
I've not looked at the costs involved with the S54 but I would assume it's more than an S50, so would need to consider if it's worth the extra for a road car that's very unlikely to see any track action.
James
'91 325i Sport
ajay
Sun Mar 05, 2017 4:47 pm
Having done an S50 & S54 i would not consider another S50, although they are similar in terms of power, the throttle responce & pick up of an S54 is way superior, 8k rpm in an E30 is always a thrill & use of the sport button adds to the experience in a way that eclipses an S50. I do agree that the S50 engines look more period correct in an E30 though.
