Where to buy the SI batteries
Farbbm
Post Fri Mar 03, 2017 1:41 pm
I've taken out my dashboard binnacle as the odometer stopped working which I've now resolved , but thought I'd see if the SI batteries could be replaced at the same time as my service lights don't work and the inspection light remains on? The car is a 1987 325 sport which seems to have the stubby lithium batteries so I just wondered where I could get 2 from? I'm also missing the brake pad wear and temp gauge bulbs from it so can I get these from BMW or anywhere else fairly cheaply?
minesapint
Post Fri Mar 03, 2017 1:46 pm
minesapint
Post Fri Mar 03, 2017 1:47 pm
Farbbm
Post Fri Mar 03, 2017 4:30 pm
Not sure that really answers my questions.
Post Fri Mar 03, 2017 5:13 pm
http://www.e30zone.net/e30zonewiki/inde ... _Batteries
As said, suppliers typically include CPC-Farnell, Maplin, RS, etc.
Post Fri Mar 03, 2017 7:37 pm
The batteries you need are LiMnO2, 1/2 AA size, tagged for circuit board fitting.
The current CPC offering appears to be BT05108, which has wire leads so should be a universal fit, BT05111, which has tags, but only one at each end (original has two on + end),and BT05105 which has the correct number of pins, and is probably a direct replacement.
Note which end of the originals is the + end before you remove them, and make sure you fit the replacements the same way around.
Motorhole
Post Fri Mar 03, 2017 8:15 pm
biffer
Post Fri Mar 03, 2017 10:01 pm
wow,they're cheap.
Post Fri Mar 03, 2017 10:22 pm
Same battery as CPC, but more expensive.
drakesmith
Post Fri Mar 03, 2017 11:18 pm
How many are need, as mine is up the wall?
Post Sat Mar 04, 2017 12:10 am
drakesmith wrote:How many are need, as mine is up the wall?
Two. Note that these are for boards that use the lithium batteries only.
Check which type you have before ordering.
