fuel supply line to fuel pressure regulator
E30rocknrollstar
Post Mon Feb 06, 2017 10:19 pm
When i finished my m20b25 engine conversion and went for the first start the engine was turning over but would not fire.
After a bit of poking about i noticed i had the fuel line on the wrong way round,so had the fuel supply piped up to the return line on the FPR.
So had fuel pressure to the wrong side could this of damaged the FPR in any way as iv read its a diaphragm valve.
if so what symptoms would i see if damaged FPR
cheers guys
ross_jsy
Post Mon Feb 06, 2017 11:06 pm
I've managed to do it more than once with no ill effects to the FPR
Post Tue Feb 07, 2017 12:46 am
There was a thread on here last year where someone had done this and it did damage the regulator.
IIRC, after being reconnected the right way around, it eventually sorted itself out an started working properly again, but the owner changed it anyway.
E30rocknrollstar
Post Wed Feb 08, 2017 9:25 pm
How would i know if the FPR was not working correctly Brian ??
ross_jsy
Post Wed Feb 08, 2017 9:41 pm
With a fuel pressure tester.
Post Wed Feb 08, 2017 9:54 pm
ross_jsy wrote:With a fuel pressure tester.
Cheap kits are only about 13GBP on ebay, and can be used to diagnose injector and fuel pump problems, as well as test the FPR.
paultv
Post Fri Feb 10, 2017 12:58 pm
I bought a tester kit, what a bloomin' joke, none of the connectors fit to each other, all the threads are different sizes or pitch, no way to attach the T piece to the gauge or the gauge to anything else !! utter crap - buyer beware!
Paul :-)
Post Fri Feb 10, 2017 1:03 pm
Take it to a specialist that knows about E30's would be my advice :)
