S54 swap. What parts, have donor car.
grants50
Fri Jan 27, 2017 10:48 pm
Luckily I never started my s50 swap and now I have e46 m3 donor car.
Obviously I have engine, box and loom out already. We want to scrap the car asap so what else do I need from it?
I want to use flyby wire throttle.
Do I need the fuel pump? I still have my s50b32 pump.
Any help would be much appreciated.
Oh also selling my 69k s50b32 complete engine and loom with ACL shells, arp rod bolts that was installed at 67k. Also have the clocks to confirm mileage.
Sat Jan 28, 2017 8:45 am
Dont forget the fuel reg which is attached to the filter, best to remove the body loom complete, you will sell all the suspension easily, if its a later one remove all the ABS parts as it will be worth fitting to your E30
Where abouts are you?
grants50
Sun Jan 29, 2017 7:01 pm
Cheers mate.
Full race car bud so no abs or anything. I'll make my own loom. Dash full of switches.
I'm haverhill suffolk
