bmw e30 320 -86 m50swap
- Brianmoooore
Does rev. counter register cranking RPM?
Five pin DME relay in the correct socket? The one with a wire connected to the centre pin of the base.
Does the DME relay click when you pull it out or insert it with the ignition on?
it dosent register crank rpmBrianmoooore wrote:Does rev. counter register cranking RPM?
its correct socket and it click when i put it in
but its an automatic harness so i have to jump two cabels but i dont know where
- Brianmoooore
Does the car crank/starter motor work?
- Brianmoooore
In that case you must have already sorted the loom to remove the auto start inhibitor.Eeken98 wrote:ya the motor is cranking goodBrianmoooore wrote:Does the car crank/starter motor work?
What colour is the label on the engine ECU and is it a 413?
colour is green and its an 405. and its an m50b20 engineBrianmoooore wrote:In that case you must have already sorted the loom to remove the auto start inhibitor.Eeken98 wrote:ya the motor is cranking goodBrianmoooore wrote:Does the car crank/starter motor work?
Is this correct for the M50B20 engine?
According to this list, the 405 is for the M50B25. On your other thread, you mention an M50B25 vanos with a 413 red label ECU.
http://www.bimmerboard.com/forums/posts/93519
