Maps for 1.3 Montronic
TriggerFish
Post Fri Dec 30, 2016 8:11 pm
Hi all,
I've got an m20b28 with a 272/272 schrick camshaft running a speedtouch chip. New single prong spark plugs (whatever the recommended ones are), new distributor, new rotor arm, but original coil and leads. All vacuum pipes (FPR, rocker cover -> throttle body and brake booster) have been replaced.
It runs perfectly - lovely and torquey (for what it is) with a decent powerband, albeit a bit lumpy at idle, which it can often hunt to find for a few seconds and it's generally a bit of a dick to start when it's a cold ambient temperature (sounds like a lumpy v8 drag racer for the first few minutes if left to idle, which I do quite like :D).
Anyway, it's over fueling from what I can tell - it smells very petrolly (a friend followed me back from a meal the other day, and asked her partner in their car what the smell was - apparently it's was the unburnt petrol out of my car - I didn't realise it was that bad!) and if held at constant revs, you can hear a frequent popping noise from the exhaust. MPG is at around 23.5 for a mostly A-road commute.
I've not had it rolling roaded/checked the AFR yet. Is there anyone who can do 'live mapping' for the 1.3 Montronic system? I know it's not as simple as plugging in a modern car, but I guess it must be possible with an eeeprom chip emulator? Failing that, does anyone deal with flashing new maps/chips, testing them, modifying them, reflashing etc.?
Cheers!
Joe
ross_jsy
Post Sat Dec 31, 2016 12:42 pm
Have you looked at the Miller WAR system?
It replaces the standard EPROM chip with one that can be rewritten, it can't be live mapped though.
Think you might struggle to find someone who can flash the stock EPROM these days, but I might be wrong
TriggerFish
Post Sat Dec 31, 2016 3:51 pm
Thabks for the suggestion. I have, yes although had forgotten them tbh. The throttle response improvement makes those quite tempting too as they replace the AFM I believe?
I know a proper map wouldn't be cheap, but with import duty etc the war chip gets quite pricey. But then again, it would be tweakable if I change anything else in the future.
Definitely something to look back into though - thanks.
