Vibrating gearbox - prop carrier?
schnaarf
Post Wed Dec 07, 2016 11:16 am
I've had a vibration from the seats for a while which I guessed was the prop carrier - but having had it up on a ramp today and driving it at 20mph, the end of the gearbox bounces up and down, quite alarmingly.
Gearbox and engine mounts look ok albeit slightly compressed - they don't deform much when taking weight off. Guibo has small cracks but nothing compared to previous ones I've seen.
There is no vibration at the diff end.
Would a worn prop carrier cause the box to bounce up and down?
Post Wed Dec 07, 2016 1:33 pm
Check the bush in the gearbox output flange that keeps the prop. centered in the guibo. If this is worn, then if something (like the centre mount) is damaged, it would allow the front to vibrate.
schnaarf
Post Wed Dec 07, 2016 9:58 pm
i will check - thanks. Is it common for the gearbox to bounce?! Haven't heard it before
Brdjo
Post Mon Dec 19, 2016 6:46 am
Did you find out what is the problem?
schnaarf
Post Mon Dec 19, 2016 8:20 am
Not yet- going to convert it to manual but will check the bush Brian mentioned when I do and report back.
gaszman
Post Mon Jan 02, 2017 9:28 am
any news on this mate
schnaarf
Post Tue Jan 03, 2017 5:50 pm
The only part that was bad was the rear CV joint.
I'm part way through a manual conversion which would be complete if the parts were correct. That's being sorted though.
Brdjo
Post Wed Jan 04, 2017 12:26 pm
CV joint on rear axle did that? 8O Glad to hear that you sort things up..
schnaarf
Post Thu Jan 05, 2017 8:01 am
No mate- I didn't see anything wrong with any part other than the prop shaft cv joint at the diff. Odd as the diff didn't move- only the gearbox end
