Thinking it was the same after verifying the fuel pump was not spinning during cranking I ordered a new one and swapped her a few days later. No difference.. Now I have a spare LP fuel pump...
Since then Ive done the following:
1) New low pressure fuel pump. I originally thought that was the problem. OEM. Main fuel pump is new from last summer. Bosch.
2) New TDC sensor. This one was actually dead so I thought that would solve the problem.. It didnt.
3) New CIS sensor. Engine speed sensor was fine: tested good at 850 ohms.
Confirmed the reference pin on the flywheel was actually there. It is.
4) New main relay.
5) New Fuel pump relay.
6) Tested the coil - 12V with key on 2, 12V cranking.
6.5) Checked the plugs from the rotor but not the individual spark plugs
7) Tried to jumper the OBC ignition wires - no effect.
9) Disconnected/reconnected the DME a few times - no effect.
10) Ran a wire direct from the #11 fuse to the LP fuel pump while cranking to see if there was a broken wire - the pump did not function (I tested the pump on 12V directly just before and it worked.)
11) I managed to swap the ECU into another m3 back in September - that car ran fine - so ECU is not the problem...
It must be a wiring or ground issue... maybe the M3 gods are angry at me..
Its important to note the car had been flawless until this. Never an issue starting idling or running... I posted this on s14.net and got a lot of help but no solution yet..
Any ideas anyone????
The horror...
