diavia retrofit a/c
randomdave325
- Random E30 Nutta
hi all. hope all is good, has anyone got the wiring diagram for the diavia a/c they sadly put on some e30's? uses a single e30/e28 a/c switch and need to know which wire goes where on the switch? it's nothing like the original bmw a/c wiring
The current fleet!
1990 318iS
1984 528ise
1987 325i sport
1990 325i cabrio
1987 m3 s50b30
'Turning money into noise'
Can't help you with the Diavia wiring, sadly, but if the switch used is the same as for the factory system, then the wiring around the switch area for that may help: http://www.autolib.diakom.ru/CAR/BMW/19 ... /fig05.pdf
