M52 b30 stroker rebuild back on the road
cheers Paul , buying your old one and tweaking it was ok but postage on the full system was the killer , i have faith in my m50 turbo touring buildmeister mate Craig
+ a yard full of scrap turds
No doubt about that really! I don't think I would trust couriers keeping it in one piece either due to the size. Get some videos up when it's done ;)
will do mateCook318IS wrote:No doubt about that really! I don't think I would trust couriers keeping it in one piece either due to the size. Get some videos up when it's done ;)
- Cypriotgeeza
I'm looking forward to seeing and hearing this!!
Check my M30 build threads:
jimbom30cab
- Tech 1 freak
Visiting hours !
LOL
Looks like a good job
LOL
- Cypriotgeeza
Is that now 50mm all the way through?
- Cypriotgeeza
I need to do this to mine!magpie wrote:yes two 50mm pipes from start to finishCypriotgeeza wrote:
I'm positive it's losing a few horses from the 50 - 46mm drop!
think mine was restricted at the manifold flange looking at the soot on it , he's also changing the inlet pipes on the scorpion back box to 50mm so it's all free flowing , no restrictions
- Cypriotgeeza
magpie wrote:pass the tissues![]()
f00k me this car is canny quick like
seems to be up in the 6.5k rev mark instantly now .
been at the unit from about 1pm till bloody midnight though just so i can have it back, think i might of woke the street up like, because race car innit haha .
the diff bush was in a box of bits i got with a breaker i bought and thought i might as well use it, not sure on the make of it but probably powerflex .
had the car back for an exhaust tweak which took 5 hours of fettling [ overwatched ] , the guy is a surgeon@ Artic Welding . I had blowing from the sleeve slots and the steering linkage was catching a bit when shown a roundabout driven properly
, this made things a bit touchy cloth i shit you not .
next up is a dyno run , it's about time we had some figures
- Cypriotgeeza
It certainly is time we had some figuresmagpie wrote:had the car back for an exhaust tweak which took 5 hours of fettling [ overwatched ] , the guy is a surgeon@ Artic Welding . I had blowing from the sleeve slots and the steering linkage was catching a bit when shown a roundabout driven properly, this made things a bit touchy cloth i shit you not .
Looking forward to it mate!
i dont believe that torque curve, looks like 200Nm at about what would be 3000-ish rpm. i bet it has way more than that in reality it should be 200 lb-ft. Should be a torquey beast that looks far too peaky
E30 325is with M20B31
it'll be getting done again next year at a different place and compare the two results innitreggid wrote:i dont believe that torque curve, looks like 200Nm at about what would be 3000-ish rpm. i bet it has way more than that in reality it should be 200 lb-ft. Should be a torquey beast that looks far too peaky
sounds like a plan, the number of dodgey looking printouts you see is ridiculous, some operators must either be hopeless or their equipment is and they still expect you to pay them. i avoid no name dynos these days, its hard enough to get relaible and consistent data from the bigger name ones. look for a Maha if you can they seem to have their act togethermagpie wrote:it'll be getting done again next year at a different place and compare the two results innitreggid wrote:i dont believe that torque curve, looks like 200Nm at about what would be 3000-ish rpm. i bet it has way more than that in reality it should be 200 lb-ft. Should be a torquey beast that looks far too peaky
- drakesmith
Heymagpie wrote:well here's the long awaited results >>>>>>>>>>>>>>
that'll do me nicely thanks![]()
Is that with your ECU Remapped?
go away rich318i your boringdrakesmith wrote:Heymagpie wrote:well here's the long awaited results >>>>>>>>>>>>>>
- drakesmith
Excuse me! I would be intrested if thats with or without a remap..??
it made 225 lb-ft today and 242 bhp ... earlier on in the day that is .reggid wrote:i dont believe that torque curve, looks like 200Nm at about what would be 3000-ish rpm. i bet it has way more than that in reality it should be 200 lb-ft. Should be a torquey beast that looks far too peaky
Sounds bad - what are the symptoms - engine seized, or summat?magpie wrote:i think my oil pump failed today .... something expensive certainly did
not quite , it still runs but oil light is on and top end is noisy .Speedtouch wrote:Sounds bad - what are the symptoms - engine seized, or summat?magpie wrote:i think my oil pump failed today .... something expensive certainly did
