Bonus/boast
corkie
My obc has had screen bleed for some time now!while cleaning my garage out today i found a old non working one but the lcd screen was good so i swapped them round and now i have a working obc!chuffed!!
e30
We all need a little bit of luck now and then
Cool
Cool
corkie
Tell me bout it if it wasent for bad luck i wouldnt have any !!
e30
bab-91
I felt like that when I changed a fuse all by myself!.
Take that Brianmoore!
IG - bab91
IG - bab91
But did you work out why it blew?bab-91 wrote:I felt like that when I changed a fuse all by myself!.
bab-91
........Brianmoooore wrote:But did you work out why it blew?bab-91 wrote:I felt like that when I changed a fuse all by myself!.
Yes?
IG - bab91
IG - bab91
steve_k
NO thenbab-91 wrote:........Brianmoooore wrote:But did you work out why it blew?bab-91 wrote:I felt like that when I changed a fuse all by myself!.
Yes?
Gert_8
What did you have to do and was it easy?corkie wrote:My obc has had screen bleed for some time now!while cleaning my garage out today i found a old non working one but the lcd screen was good so i swapped them round and now i have a working obc!chuffed!!
corkie
Prety simple i took both apart and swapped the lcd screen!two tags top and bottom seperate the back and front, then undo the screws inside the front bit and the lcd can be removed!if you meed further help let me know!
e30
Captain_Birdseye
Is Brian Moore a robot?
Gert_8
Thank you.corkie wrote:Prety simple i took both apart and swapped the lcd screen!two tags top and bottom seperate the back and front, then undo the screws inside the front bit and the lcd can be removed!if you meed further help let me know!
