anyone got a compression tester around Hampshire?
parakeats
Post Tue Sep 20, 2016 11:14 am
As above, planning to get things compression tested before I rip off the head and expect to find a blown head gasket.
Currently experiencing a slight misfire on startup for a few seconds, milky underside of the cap and solid coolant hoses on an m40 318i
If anyone has a compression tester and fancies some beer in payment, I'm in Winchester :)
bobbin1982
Post Tue Sep 20, 2016 8:33 pm
does the heater blow hot air?.... if not its the headgasket in my experience
Driving my digger!!!!
parakeats
Post Wed Sep 21, 2016 2:45 pm
it does sometimes, when it's idling it sometimes goes cold, but if you keep the rpm around 1.5k, it warms up quickly, almost as if it's not circulating that well at low rpm?
bobbin1982
Post Sat Sep 24, 2016 9:14 pm
sounds like the waterpump is failing and it has enough for the headgasket to have shit itself
But im no Mechanic just an unlucky soul who has experienced such things
