Interior light - Driver side not working
E30M3EVO
Tue Sep 20, 2016 9:25 am
Guys,
When i open the door the interior lights do not come on. But when I open the passenger door the interior lights come on.
Troubleshooting steps so far taken:
1. Checked driver side bulb - ok
2. Swapped the dome for a known working
3. Swapped the door switch
Been told it may be a wire in the A pillar that may be at fault or central locking system.
Can anyone shed some light on this or experienced a similar issue.
ChrisHC
E30Zone Contributor
Wed Sep 21, 2016 2:06 am
It is not clear from your post whether the driver's side light comes on when you open the passenger door. If it does, then there is nothing wrong with the light. If it does not, then there might be something wrong with the light. The three way switch on the light is a rather crude device and is subject to the heat from the festoon bulb; it might be the problem. I would start by testing whether there is power there when the driver's door is opened and whether there is a good earth there and the switch works properly. I do not see how the central locking can be involved but the interior light delay unit is mounted alongside the central locking unit to the side of the driver's footwell.
Wed Sep 21, 2016 9:32 am
The first thing that needs to be established is whether you have the fairly rare option of an interior light switch off delay 'relay' fitted to your car. These are connected to the driver's door only, so if fitted, and faulty, will only affect that door.
Unscrew the driver's door pin switch again, and tell us what colour wires are attached to it.
E30M3EVO
Wed Sep 21, 2016 9:33 am
Thanks Chris,
I was checking this lastnight, the following are the findings:
1. When I open the passenger door, both passenger and driver side dome light up
2. When I open the driver side door, none of the dome's light up.
3. Manually switching on the driver side dome works
I have checked the switches and swapped them are working.
So i assume it may be the wiring..? Where is the earthing..?
bobbin1982
Wed Sep 21, 2016 6:00 pm
Brianmoooore wrote:The first thing that needs to be established is whether you have the fairly rare option of an interior light switch off delay 'relay' fitted to your car. These are connected to the driver's door only, so if fitted, and faulty, will only affect that door.
Driving my digger!!!!
E30M3EVO
Thu Sep 22, 2016 10:03 am
Thanks will have a look today and let you guys know. :)
E30M3EVO
Thu Sep 22, 2016 6:17 pm
I have had a look, two wires are connected to the switch of the following colour:
Brown/Yellow
Brown/Blue (purpley blue)
Thu Sep 22, 2016 7:26 pm
Brown/blue is the wire for the relay that enables the windows to work with the doors open and ignition off, and brown/yellow is indeed the wire that controls an interior light delay unit, so it looks like you have one fitted.
If there wasn't, the second wire would be brown/purple.
The light delay unit uses the same power feed (red/black wire) as the central locking, so the first question is: does the locking work correctly?
There is a switch connected to the driver's external door handle that needs to be in working order, along with the wire from it to the delay unit, which passes through the infamous A pillar plug and socket for the door wiring loom. This is a brown/green wire.
Wiring diagram here: http://www.autolib.diakom.ru/CAR/BMW/19 ... /fig11.pdf
E30M3EVO
Thu Sep 22, 2016 10:08 pm
Thanks Brian
The central locking works perfectly and works with the alarm fob aswell.
I will check the brown/green wire and see if its all connected accordingly.
