Just noticed the odometer and trip gauge not working,
where do I begin?
Odometer and trip gauge failure
pierce
Start by checking the wiring to the diff sensor.
After that, check for solder problems on the back of the odometer.
After that, replace diff sensor.
If the speedo. is working, there's nothing wrong with the diff. sensor or its wiring.
I see you live somewhere that's generally a bit warmer than the UK, so it's likely that you have the problem that seems ro afflict US cars, where the plastic gearwheels that drive the odometer have failed.
IB6376CY
Indeed...Mallorca....yes, speedo is fine, so I guess this means getting in to the guts of the instrument housing?
satan16v
I've just had the same problem and ordered new gears for my speedo from this guy...
http://www.ebay.com/itm/281404355846
Message him first to make sure you've the correct gear ratios, he's very helpful
E30 325i - In progress
E53 X5 4.6is - SOLD
E46 320d Sport Tourer - SOLD
E36 M3 - SOLD
E34 535I Sport - SOLD
E53 X5 4.6is - SOLD
E36 M3 - SOLD
instrument cluster comes apart easily enough - pull out the coding plug on the front right lower corner, remove all the self tapping screws around the outside of the rear of the case, and pull the two halves apart. SI board stays in the front half, rest stays in the back.IB6376CY wrote:Indeed...Mallorca....yes, speedo is fine, so I guess this means getting in to the guts of the instrument housing?
Unscrew the two screws on the back, behind the speedo, and pull the speedo assembly out. No idea how to change the gears, since it's a totally unheard of problem in the UK.
satan16v
2 screws hold the gear cover on
The gears just ease off
E53 X5 4.6is - SOLD
E36 M3 - SOLD
E53 X5 4.6is - SOLD
E36 M3 - SOLD
sideshowbob
Hi,
I am based in the UK but my E30 was originally from Hong Kong and reimported to the UK.
The car is a 325i convertible and the odometer / tripmeters have just stopped working.
As the speedometer is still working I am thinking the gears have failed.
My question is are the gears the same for all models 318, 320 and 325 and is there any difference between MPH and KPH as my car has a KPH speedometer.
Buis
Gears broken. Check if you have vdo or motometer. You con order on the website from garagistic. They ship fast.
Best to do: pull out, and then order parts.
323i Balticblau metallic 2 doors. 02-1984
IB6376CY
Many thanks for the informative replies.
IB6376CY
Successfully delved into the speedo unit to find the small gear on the drive shaft has failed, all others (there are four) look good. It's a VDO unit reading kilometers. Now to source replacemets. Again, thanks for your input and thanks to Youtube!
