318Is m52 turbo and restoration
jasp
Tue Dec 08, 2015 8:36 pm
The plan is to have a mint rust free shell with a turbo m50, 5 stud conversion, 325 sport diff, z3 rack and short shift, a set of bilsteins and some nice 16s
I think 350 whp will be nice for a suday blast on a sunny day.
I'm still undecided on gearbox and management choice.
I bought my second e30 three and a half years ago, a 318is. It came lowered on apex suspension a blowing exhaust and pretty much everything else was standard.
The first and only mod i put on was a volvo splitter
I used it daily for a year untill i started poking the inner arches, which turned out to be rusted through and hidden by a lot of stonechip and a bit of fibrefill.
So i bought e30 number three, a 325 which had been parked in a garage for a few years with no interior. The shell was immaculate not a patch of rust to be seen. A set of mims, cheap interior, headgasket change and second hand rad and she was good to go.
A week later minding my own business some kind woman decided to drive straight into the side of it
Yes i did throw my toys out of the pram a bit
My Is had been living on the drive looking sorry for itself for just over a year due to lack of time and a place to work on it untill recently
stole the battery off my scooby and she fired straight up
sold the engine to a friend for his Is
then i decided to go to Australia for 9 months so very little happened.
Came back 3 months ago and made a bit of a start
bit of work on the daily
making some brackets for a spit
which brings me to were i am now, ready to start attacking all of that pesky rust
toby
Thu Dec 10, 2015 2:35 pm
Getting stuck in there then! Shame about the 325i. Was it a write off?
jasp
Fri Dec 11, 2015 5:30 pm
Yeah unfortunately it was another e30 which will never see the road again. The insurance tried to pay out peanuts for it saying it was only worth £1000
jasp
Wed Dec 16, 2015 10:52 pm
started attacking the rust
and then my welder decided to play up and die :(
choppermeir
Sat Dec 26, 2015 10:43 am
Very nice repair panel
jasp
Sat Feb 13, 2016 10:40 am
progress has been fairly slow due to work, but ive managed to get a bit more sorted
jasp
Sat Feb 13, 2016 10:46 am
i also have an engine, it is an m52 but i got the whole car for £300 so it will do :D
So i am on the hunt for a e34 sump etc if anyone has one kicking around
P_VIDDY
Tue Feb 16, 2016 8:19 am
Oh the battle of rust. The war all e30 owners fight. :twisted:
good luck with the project
jasp
Tue Feb 16, 2016 5:55 pm
P_VIDDY wrote:Oh the battle of rust. The war all e30 owners fight. :twisted:
It seems to be the common enemy :evil:
Thanks, i just can't wait to drive it
pauljsc
Tue Feb 16, 2016 7:16 pm
How did you get the car for £300? Bargain! I just got my second e30 320i just like your grey 325. It's had all the body rust sorted and re sprayed and everything's stock so far. First mission is to lower it. What suspension did that 325 have?
pauljsc
Tue Feb 16, 2016 7:19 pm
hillbilly30
Tue Feb 16, 2016 7:41 pm
http://s914.photobucket.com/user/jasp90 ... 8.jpg.html
Another HRT plate. My "IS" is H5** HRT. Same dealer I guess
jasp
Wed Feb 17, 2016 10:30 pm
jasp
Wed Feb 17, 2016 10:32 pm
hillbilly30 wrote:http://s914.photobucket.com/user/jasp90 ... 8.jpg.html
That's cool, don't think I've ever seen another one on HRT, would be interesting to find out which dealer it was
_Dan_
Sat Feb 20, 2016 8:34 pm
Nice repairs :)
Emerald standalone, engine builds + e30 repairs - TheEngineShedOnline@gmail.com
jasp
Wed Mar 16, 2016 10:12 pm
bit of an update
pulled the motor and box out of the e36 on my friends drive
rusty footwell
getting there
jacking point was rotten through all three skins
things are about to get serious 8O
the point of no return
just have to finish welding it up, seems to have lined up well and no major warping :thumb:
i hope the other side goes just as well
jasp
Sun Apr 17, 2016 7:28 pm
finished off the drivers arch
fully welded and ground down
inner arch
the bit where the filler neck sits was a right pig
rear battery tray
passenger arch
oh and this came in the post :D
hx35 with 12cm housing, just need to weld the wastgate closed so i can run external
Sun Apr 17, 2016 8:30 pm
Well done, plenty on here would have scrapped that :cool:
jasp
Sun Apr 17, 2016 9:15 pm
DanThe wrote:Well done, plenty on here would have scrapped that :cool:
thanks, out of all the cars ive owned this one has been my favourit. wouldnt dream of sending it to be bean cans :D
jasp
Sun May 15, 2016 9:17 pm
few spots on the rear panel
rear valance
wire brushed all of the loose stonechip and all the seams, then rust cured all seams
found a few more bits of rot which needed cutting out. it never ends 8O
wire brushed\rust cured engine bay seams and front panel then given a quick blast with zinc primer
just need to weld up the fuel tank mounts and the shell is finally rust free :beer:
appletree
Mon May 16, 2016 6:46 am
Great work, seams like a mission at the time but when you start to see the light at the end of the tunnel or rather when you can't see the light shining through the rust holes you get a sence of achievement knowing you can finally say it is "rust free" :D
Ashley1995
Tue May 24, 2016 3:55 pm
Wow some seriously good work there, look forward to updates
jasp
Sat May 28, 2016 9:32 am
cheers guys its getting there slowly :)
jasp
Sat May 28, 2016 9:54 am
sorted tank mounts
seam sealered alll underneath and in the engine bay
outside for the first time in months and given a coat of upol gravitex
got my paws on some super thick industrial paint so gave the arches a quick brush
straightened up my old valance as it had a run in with a hare and did some modification to get a bit more airflow
think im going to either leave the plastic blank out or weld a plate in and drill some more holes
next job is to give underneath a coat of red and take it off the spit ready for primer
jasp
Wed Jun 15, 2016 6:19 pm
got out my shiny new spray gun and put some red on
made a trolly
took the shell off the spit and started filling the rear arches
filled a small dent in the roof and a few carparking dings on the rear quarters
arches done :D
rolled her outside and got a coat of high build primer in the engine bay
_Dan_
Wed Jun 15, 2016 6:55 pm
Nice work :)
jasp
Sun Jul 17, 2016 10:41 am
_Dan_ wrote:Nice work :)
thanks mate.
I was planning on using vems ecu to run my turbo. What are the emerald ecu setups like? would you be able to do the mangment and mapping on my engine? would be quite handy seeing as your only down the road :D
jasp
Sun Jul 17, 2016 11:12 am
been a bit slow these past few weeks but managed to primer the whole shell 8)
fillered and rubbed down the doors, bootlid and bonnet
repaired my front valance
trial fitment
decided i didnt like the holes i drilled so it will have this one on instead, cut out blanking plate mount for the intercooler
Sun Jul 17, 2016 8:08 pm
nice project 8)
jasp
Sun Jul 17, 2016 10:45 pm
magpie wrote:nice project 8)
thanks, its coming along slowly :D
mattmk1
Tue Jul 19, 2016 12:31 pm
Good stuff, i can appreciate the work going into this!
jasp
Sat Jul 23, 2016 8:40 pm
splashed a bit of red at it
primered the doors, bootlid, valance, and bonnet
and finally today i sprayed the engine bay and boot
happy with the finish ive managed to get as im doing it outside and ive never really sprayed a car before
hopefully my front wings and sunroof panel will turn up soon and then its off to the paint shop for a full spray :D
jasp
Mon Sep 19, 2016 4:26 pm
progress has been slow lately
took my mirrors apart ready for painting
stonechipped around the sill's front and rear valance
rubbed down my bumpers and se sideskirts
dismantled my rear subframe, pressed out the wheel bearings and run the wire wheel over it all.
still no sign of my wings or sunroof panel 6weeks on :x starting to wonder if they will ever turn up. Anyone used 'bavarian retro' in scotland? keep getting told he "will post them this week" for the last 3 weeks
Mon Sep 19, 2016 4:36 pm
don't say he's called Boyed ?
jasp
Sat Sep 24, 2016 10:17 am
magpie wrote:don't say he's called Boyed ?
thats the one. Have you had problems getting parts from him too?
