My ignition switch had died so I'm fitting a push start and ignition switch I had kicking about in the garage. The car is a track car anyway.
I have the majority of the wiring sussed but I'm slightly stumped by the small white connector with a grey and a grey/brown stripe wire.
I've done some searching about and can't find info on it, it's not mentioned on the wiring diagrams I have found so just wondering if I can leave it disconnected if it's something like the radio on signal for key pos 1?
Here is the little plug
Thanks in advance
