Hi guys looking to replace my old leaky radiator with a brand new one. I have found three different Nissens ones on eBay but I'm not quite sure which ones will fit.
My old radiator is 380mm in length, one of the cheaper ones I have found is 440mm in length. So my question is, will this fit in the standard mounts as it is a longer item, or shall I jus pay a little extra for the 380mm item. As you can imagine I am thinking if the bigger one fits then why not go for that as it's also cheaper, and will help that little extra with cooling.
M40 radiator which one...??
