m10 will start but cuts out right away
demelle155
Sat Jul 02, 2016 12:46 pm
hi guys
i had a problem yesterday drivinghome from work
i heard a loud bang in the engine bay and the car started losing power then i heard another one and the car only went up to 40km/h on full throttle then it died on me.
Now i towed it home but it will start it turns for a second or 2 then it dies.
i have spark on all the 4 cilinders fuel pump is ok i can hear it at start up.
it's a 318 auto from 1985 with lpg conversion but the car has it on lpg and on normal gas so i think fueling is ok
toby
Sat Jul 02, 2016 2:33 pm
Have you checked the condition of the rotor cap and arm?
demelle155
Sat Jul 02, 2016 2:34 pm
yea no problems there
Sat Jul 02, 2016 3:47 pm
How does it sound when it starts up - running on all four pots, or missing on one or two?
demelle155
Sat Jul 02, 2016 4:12 pm
sounds good like it runs normal but it stalls right away after start up
however when i start it and give full gas it backfires into the aircleaner???
Sat Jul 02, 2016 6:07 pm
Sounds like it could be a clogged crankcase breather, or leaking vacuum pipe issue; check all the rubber hoses for splits.
demelle155
Sat Jul 02, 2016 7:55 pm
k here's what i found all lines are good but are connected different then my other m10 car but that's a manual?
-the vacuum line from the distributor goes direct into the intake manifold on the other one it first goes to the little thing on the firewall.
-line that goes to the throttle body from the block is connected to the opening above the starter
-throttle body opening is open.... talking about the big connection not the little one like the dizzy cap
demelle155
Sat Jul 02, 2016 8:20 pm
this is the connection i mean at the throttlebody the weird thing is it ran like this no problem
demelle155
Sun Jul 03, 2016 11:18 am
ok i'm embarresed to say this but hey it's fixed.... put in some lpg gas and it drives again :wink:
Sun Jul 03, 2016 5:22 pm
Worth looking into what may have been attached to it though, and ensuring it's either re-connected or plugged if required...
