Cage to rear subframe mount points.
Sx279
Post Thu May 26, 2016 12:14 am
Has anybody got and info on cages that go to the rear subframe mount points (wear the long stud drops though the floor for the subframe bush)?
Im building a new cage soon and i am going to incorporate the subframe pick up points into it but i want to find out if the long stud goes though the cage (using a longer stud) or if the cage is just welded to were the stud goes though?
If anyone can shed any light on this it would greatly be appreciated.
AdamGardner
Post Fri May 27, 2016 9:28 pm
My cage picks up the rear axle points, I still have the original axle bolts. the cage I guess will just help reduce the flex in the shell.
Sx279
Post Sat May 28, 2016 4:07 pm
Was longer bolts used then ie the bolt went through the cage then the floor to the frame? Or was the cage just welded to the floor around the hole that the bolt goes through?
Post Mon May 30, 2016 6:06 pm
These might be of interest
ross_jsy
Post Mon May 30, 2016 6:38 pm
My 18 point Safety Devices cage bolts to the rear subframe pick ups. It came with bolts but I can't remember if they were longer or not. They were to replace the standard ones which are splined into the car if that makes sense
Sx279
Post Tue May 31, 2016 12:04 am
Thanks dan don't suppose you no if the cds was capped at the bottom with a hole big enough for the frame bolt to go through or if the bolt stays were it is and this plate just welded over the hole in the floor do you?
Thanks for the replys..
