So far I have been fixing little things inside and out, like new fog and indicator lenses, replacing broken or missing interior parts. I removed a seized actuator from the passenger door, that was a tricky job as the door was stuck shut.
New fog lenses fitted
Also fixed a problem where the roof cover doesn't close fully, as you can see its perfect now. Very easy to do, 10 min job and a £30 part form BMW.
Most recently I stripped the front end off to replace all worn suspension parts etc, lots to buy now. Also the lights, grill etc to clean it all up and replace the cloudy main beams.
Still lots to do and its going take around 2 years and I have budgeted about £5k. I don't have a lot of time as I am doing up a house to but will update when I can.
If anyone has any tips or advice feel free to shout and visa versa but I am no mechanic.
