Windscreen washer
ravstar13
Post Wed Apr 20, 2016 1:28 pm
i have tried to search this, but cannot find anything on it, It seems the water leaks when I put the washer on from the top of the bonnet, would I require a double ended pipe? if so what sizes am i looking for and im guessing easy to fit?
Post Wed Apr 20, 2016 1:44 pm
If you mean it leaks from a hole in a circular valve under the bonnet, then this is very common.
New valve required.
ravstar13
Post Wed Apr 20, 2016 1:53 pm
Thank you Brian, can this be easily installed and can I get it for Euros?
