Adv needed: just done a drift and now steering squint??
freakytate
Post Wed Apr 06, 2016 6:29 pm
Hi. Im after just some suggestions really. I was out in my e46 330d just now, its open diff so doesnt really go sideways much but spins up. I went round a small roundabout and give it some beans and the car went into a real nice smooth drift. Drove off as normal but now my steering wheel is squint and my tracking really bad. I cant understand, I didnt mount a kirb or nowt.
Poked my head under car and around wheel and its possible my rear bush has pulled out towards front a little. Not sure but one may have. Is this possible? I dont know how they are fitted or pressed? Nee to e46 scene.
Post Wed Apr 06, 2016 6:48 pm
Id be more concerned about the boot floor than the bushes :D
freakytate
Post Wed Apr 06, 2016 10:41 pm
Why? Shes rotten all over not just the boot if thats what you mean ha
ross_jsy
Post Wed Apr 06, 2016 10:54 pm
E46's, being the budget turds they are, like to rip boot floors out for fun
freakytate
Post Wed Apr 06, 2016 11:00 pm
At first i was expecting my axle to be hanging off when i get out. Definately something on front, the pass wheel is pointing out :(
freakytate
Post Fri Apr 08, 2016 9:25 pm
put her on ramp today. my bottom arm inner ball joint stud has bent allowing my arm to pull forward, back bush shafted too. found outer ball joint with play on drivers side too :?
maxfield
Post Fri Apr 08, 2016 9:26 pm
freakytate wrote:put her on ramp today. my bottom arm inner ball joint stud has bent allowing my arm to pull forward, back bush shafted too. found outer ball joint with play on drivers side too :?
Sounds a well maintained car.
