On inspection, the terminal on the bottom of the electrical plug has broken of and the underside area where it would seal to the tank is too heavily corroded.
Looking around at replacements, it seems they are nearly all the single pipe version and could only find one on eBay with the twin pipes which seems a no-name brand but also has a different electrical plug on top which would then mean chopping the loom and finding a correct replacement plug.
Anyone had to replace the same or know of a correct aftermarket one that's a straight fit ? Might also be interested if someone has the correct unit that's rust free to which I can replace the lift pump.
eBay part with wrong plug ?
http://www.ebay.co.uk/itm/fuel-pump-Bmw ... SwgQ9V1IYt
